how much does an fmu cost??????????
Old Jul 15, 2002 | 12:16 PM
vteckiller's Avatar
Default how much does an fmu cost??????????
Old Jul 15, 2002 | 12:25 PM
CovertFI's Avatar
Default Re: how much does an fmu cost?????????? (vteckiller)
what is wrong with your vafc? that is all your need for low boost
fmu
Old Jul 15, 2002 | 12:26 PM
inspyral's Avatar
http://www.vortechsuperchargers.com/...ries/fuel.html - $140.55
https://honda-tech.com/zerothread?id=223796 - $100
Old Jul 15, 2002 | 12:27 PM
vteckiller's Avatar
Default Re: how much does an fmu cost?????????? (CovertFI)
how much boost would that be able to deal with b/f i will need the fmu???
Old Jul 15, 2002 | 12:36 PM
Cramerox's Avatar
I would run the FMU regardless. It increses presure with reference to boost. so if ur running stock injectors, then get a 12:1 along with and inline pump.
Old Jul 15, 2002 | 12:39 PM
inspyral's Avatar
Default Re: how much does an fmu cost?????????? (Cramerox)
Also keep in mind that if you add more than +10-12 with the AFC, you're going to throw a MAP sensor code under boost.
Old Jul 15, 2002 | 12:51 PM
vteckiller's Avatar
the drag gen 3 kit comes with all of that . I just rather be safe then sorry
Old Jul 15, 2002 | 12:53 PM
CovertFI's Avatar
run the vafc with some 440 dsm's. it will work up to 10psi
Throwdown
Jun 22, 2006 05:55 PM
kholmes
May 10, 2004 07:08 PM
88crxvtec
Feb 13, 2003 07:13 AM
JeremyL
Dec 13, 2002 12:36 AM
4gvtec
May 19, 2002 09:18 AM
