How much boost will eagle H-beam rods hold?
Old Mar 14, 2004 | 10:09 AM
scooba92hatch's Avatar
Default How much boost will eagle H-beam rods hold?
As the topic asks, How much boost have people on here put to eagle H-beam rods. I have a boosted b16 with no sleeves just srp pistons and eagle H-beam rods. Thanks for your input !!!
SCOOBA
Old Mar 14, 2004 | 10:54 AM
b16ahybrid's Avatar
Default Re: How much boost will eagle H-beam rods hold? (scooba92hatch)
I beileve that you should be asking "how much power will eagle H-beam rods support". Boost is just a measure of pressure. Hp is what puts the stress on your components. 20psi on a d16 using a t3 isn't the same as 20psi on a b18c using a sc61.
Old Mar 14, 2004 | 11:43 AM
integracivic94's Avatar
Default Re: How much boost will eagle H-beam rods hold? (b16ahybrid)
i would worry about the sleeves rather than the rods they are pretty good if installed correctly! just my 2c
Old Mar 14, 2004 | 12:03 PM
11psiTurboSI's Avatar
Default Re: How much boost will eagle H-beam rods hold? (integracivic94)
I've seen 400hp and 375tq on eagle rods... with no problems at all!
Old Mar 14, 2004 | 01:36 PM
Default Re: How much boost will eagle H-beam rods hold? (9psiTurboSI)
thanks for the input
Old Mar 14, 2004 | 01:42 PM
accordfreak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scooba92hatch &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the input </TD></TR></TABLE>
since you got your answer... I'm going to ask...
what about PROBE rods???
Old Mar 14, 2004 | 02:16 PM
HEAD's Avatar
Default Re: How much boost will eagle H-beam rods hold? (accordfreak)
I've seen 850+fwhp with Eagle rods, and ARP rod bolts. Crower makes a killer Honda rod alot of Hot Rod class racers use them. I think Manley does to.
Old Mar 15, 2004 | 10:29 AM
iiilgsrlll's Avatar
Default Re: How much boost will eagle H-beam rods hold? (HEAD)
I've seen 841whp (nos/turbo)
1sicef9
Jun 19, 2010 04:58 PM
KamikazeSol
May 10, 2003 06:37 AM
1.8T_EG
Feb 5, 2003 11:01 AM
InfamousRS
Sep 16, 2001 09:36 PM
