How much boost have you put on your eagle rods?
im just trying to see what psi you turbo guys have run on your eagle rod setups with out breaking something ....ive heard some people say eagle rods are garbage and then ive heard others say they will hold ....im a little confused
Re: How much boost have you put on your eagle rods?
It wouldnt be a mtter of how much boost as it would be how much power people have made on them.
we have seen users here post up 600-800whp power on eagle rods with no problems.
if you are breaking connecting rods of any kind you doing something wrong (ecu tune), installed them wrong or used the wrong rod for the type of application.
who told you eagle rods were trash? i cant wait to get my h beams, they can handle more power than most daily drivin hondas can throw at them.... is this a full race build or dd? what are your plans
It is not bost it is the rpm that makes the big end out of round.. Eagles are soft.. I have had a b16 making 10500rpm jut a few times and eagles did not like it and destroyed the engine.. I would not recomend eagles..
I went with eagles because almost every build I found on the web where built on eagles. I believe on their site they say 900hp and like stated above its not boost its power. So if you are running less than 900hp, engine built properly, and don't want to rev to the moon you will be fine.
You can look up Bars of pure gold on the Internet and find people complaining about it.
I have the big bolt eagle ls/v 29psi and 10200 revs and been good for 4 years now. But it is time for a sleeved block.
