max boost on stock injectors
hi can someone tell me what is the max boost i can run on gsr injectors and 370's. can the stock ecu idle 370's. also i will not be using a fmu either thanks
Re: max boost on stock injectors (turbocivic22)
Stock injectors without fmu will not support any boost. 370s will be good for maybe 7 or 8 psi tops but you will need something to tune them with, either a vafc, smc+, map limiter etc...
Re: max boost on stock injectors (omahaturbocivic)
ic the reason im asking is because i have a hks f con and it is programed to run on stock injectors. i kinda thought that the stock injectors couldn't handle it. ill prob put in the 370 then
