building LSVTEC for boost what compression for pistons
Old Jun 16, 2004 | 05:50 PM
BOOSTED-EG's Avatar
Default building LSVTEC for boost what compression for pistons
Im building LSVTEC Im going to have sleeves and forged pistons and rods so i need to know what compression to use for reliability and power i have 3g hondata and a 57trim turbo with .63 ar please help
Old Jun 16, 2004 | 05:51 PM
86si's Avatar
Default Re: building LSVTEC for boost what compression for pistons (BOOSTED-EG)
9-1
Old Jun 16, 2004 | 05:55 PM
BOOSTED-EG's Avatar
Default Re: building LSVTEC for boost what compression for pistons (86si)
i was told to get 9.8:1 or 10:1 more compression less boost more power
Old Jun 16, 2004 | 06:00 PM
86si's Avatar
how much boost do you plan on running,how well built is your lower end going to be,and what is your engine management???
Old Jun 16, 2004 | 06:06 PM
BOOSTED-EG's Avatar
im going to fully build the bottom end with sleeves forged pistons and rods and all the bells and whistles i want to be able to run 25 psi on race fuel i have hondata stage 3B and RC 550 injectors it is externally gated
Old Jun 16, 2004 | 06:18 PM
86si's Avatar
again 9-1,I am running 23psi c-16 fuel,zdyne ecu on a fully built d16a1(88teg)trust me you won't be dissapointed
Old Jun 17, 2004 | 07:44 AM
Turbocivic94's Avatar
9:8:1 CP pistons here
Old Jun 17, 2004 | 07:49 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTED-EG &raquo;</TD></TR><TR><TD CLASS="quote">im going to fully build the bottom end with sleeves forged pistons and rods and all the bells and whistles i want to be able to run 25 psi on race fuel i have hondata stage 3B and RC 550 injectors it is externally gated </TD></TR></TABLE>
FYI, You are gonna need more than 550's for 25psi on a built LS VTEC.
Old Jun 17, 2004 | 08:34 AM
pete98m3's Avatar
700-800 cc injectors would do ya.
550's wont cut it without a ton of base pressure and even then i don't think they'll flow it.
Old Jun 17, 2004 | 08:56 AM
Rod.'s Avatar
Default Re: (pete98m3)
9:1 here on my ls vtec
Old Jun 17, 2004 | 12:04 PM
BEV@GSCMotorsports's Avatar
Default Re: (redturbocivic)
9:1
Old Jun 17, 2004 | 02:51 PM
AVATAR's Avatar
Default Re: (BEV@GSC)
9.8:1 here
Old Jun 17, 2004 | 05:33 PM
B18C1CYA's Avatar
Default Re: (AVATAR)
cp 9:1
supracharger19
10
Mar 18, 2010 04:13 PM
snaileg
Nov 8, 2006 04:11 PM
7rrivera7
Apr 20, 2004 03:46 AM
2000SiDriver
Apr 14, 2004 08:08 PM
