How many of you have oil temp. gauges? Need sensor location mounting info.
I have an autometer mechanical oil temp. gauge. It comes with both a 3/8 npt fitting and an adapter from 3/8 to 1/2 npt. They say to weld a fitting in your oilpan and place the sensor there. Thats not too bad, because I need to weld a fitting in my oilpan for my oil return line soon anyway. Any other place I can place this sensor? ANyone done this before? TIA
Re: How many of you have oil temp. gauges? Need sensor location mounting info. (vr6chris)
get an oil filter sandwitch adapter and put it there. or you can put a tee in your oil feed line and put it there.
Landon
Landon
Re: How many of you have oil temp. gauges? Need sensor location mounting info. (boosted_dc2)
you can do it there.... but the ideal location is in the oil pan. because thats where the oil goes after it leaves the motor... its the most accurate reading for temp.
on the sandwich will work, but thats after a few process's have happened which can alter temps.
Re: How many of you have oil temp. gauges? Need sensor location mounting info. (pornstarSR)
What type of fitting should I get than for the 1/2" npt fitting I have for the sensor?
Re: How many of you have oil temp. gauges? Need sensor location mounting info. (VacantBanana)
yes, my feed line is attached there. But in no way would the 1/2" npt fitting even come close to fitting there. It is a 1/8" npt fitting there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vr6chris »</TD></TR><TR><TD CLASS="quote">yes, my feed line is attached there. But in no way would the 1/2" npt fitting even come close to fitting there. It is a 1/8" npt fitting there</TD></TR></TABLE>
go to home depot or something and see if you can get a brass fitting to transition from 1/8 to 1/4, or whatever you need. this is more than likely where i will put my oil temp gauge, and im planning on just gettin a brass T or something
Re: How many of you have oil temp. gauges? Need sensor location mounting info. (blackeg)
My sensor is on oil pan.
There are also sensors that you can use to replace oil drain screw, and put it instead of it. Easiest way.
Yeah I would also like to know where you can get the drain plug sensor?
Re: How many of you have oil temp. gauges? Need sensor location mounting info. (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd »</TD></TR><TR><TD CLASS="quote">Yeah I would also like to know where you can get the drain plug sensor?</TD></TR></TABLE>
bump! cuz I want to know also.
Re: How many of you have oil temp. gauges? Need sensor location mounting info. (Nick7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick7 »</TD></TR><TR><TD CLASS="quote">My sensor is on oil pan.
There are also sensors that you can use to replace oil drain screw, and put it instead of it. Easiest way.</TD></TR></TABLE>
Curious also about the drain screw.
Re: How many of you have oil temp. gauges? Need sensor location mounting info. (DaX)
ya I got the same problem in looking for a spot for the sensor where do you get the drain plug sensor?
Re: How many of you have oil temp. gauges? Need sensor location mounting info. (Ls-Rturbo)
To me it seems like the drain plug screw way isnt the best way of going about it. You can damage the element if you move it around to much. Best thing to do is buy the Autometer weld fitting and put it in the pan. Thats where i put mine, a little to the side of the drain there is a flat spot...almost seems like it was meant to be put there.
CivicNewbie
01-24-2002 07:01 PM
