how far down to drill!?
Old Apr 9, 2006 | 05:50 PM
.kyle's Avatar
Default how far down to drill!?
i have a d series im in the midst of turbo'ing and i was wondering how far down on the side of the oil pan i should drill the hole for my oil return . . because i dont want any interference with my crank if i drill too high. . . if you guys have an approx that would be good. . thanks!
Old Apr 9, 2006 | 06:01 PM
I Have an STD's Avatar
wrenchin'
Default Re: how far down to drill!? (IWantATurbo)
i always to it about a 1/2 inch below the lip. never had a problem with oil backing up
Old Apr 9, 2006 | 06:08 PM
mrbsponge's Avatar
rememeber this, even if you drill low, drill towards the area of the pump pick up. oil will keep being "pulled" from this area with the motor running.
greddys oil return line takes the place of the oil drain plug, so it HAS to be able to drain from this area
Old Apr 9, 2006 | 06:41 PM
DaveF's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">greddys oil return line takes the place of the oil drain plug, so it HAS to be able to drain from this area</TD></TR></TABLE>
is it like this on all of their turbo kits?
Old Apr 9, 2006 | 06:44 PM
Soccerking3000's Avatar
Default Re: (Dturbocivic)
most of them use the a standard elbow flange that you drill into the pan between the bolts, and you want the return to be as high as possible...
Old Apr 9, 2006 | 07:24 PM
wrenchin'
greddys oil return line takes the place of the oil drain plug</TD></TR></TABLE>
what?? no it doesnt!
Old Apr 9, 2006 | 08:00 PM
Bailhatch's Avatar
Default Re: (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote">
what?? no it doesnt!</TD></TR></TABLE>
word on the street is that some do.
Old Apr 9, 2006 | 08:17 PM
Tactic$'s Avatar
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">word on the street is that some do. </TD></TR></TABLE>
Pics for proof plz
Old Apr 9, 2006 | 08:24 PM
dunkd's Avatar
i did mine as high as possible with allowing room to get the fitting on.
Old Apr 10, 2006 | 04:47 AM
D@nnY's Avatar
Old Apr 10, 2006 | 08:24 AM
wrenchin'
how?? run a line from the front of the motor all the way around to the back? or as we talking the greddy kits for the k series?
Old Apr 10, 2006 | 11:08 AM
EG1.8cT68's Avatar
on the ep3 greddy kit it diffently drains back in at the oem drain plug via a banjo bolt
Old Apr 10, 2006 | 04:46 PM
wrenchin'
Default Re: (EG1.8cT68)
weird. and this works?? i want to see pics of this B4 i believe it
mrdeadman
Jan 30, 2007 06:03 PM
teddy_dc2
Aug 10, 2006 06:11 AM
SM00TH976
May 17, 2006 08:59 AM
moesrex
Apr 3, 2006 07:35 PM
specv5150
May 8, 2004 11:14 PM
