How do u decide on cams?
Old Oct 11, 2010 | 09:59 AM
norcalB18's Avatar
Default How do u decide on cams?
How do you guys decide on what cams would be right for your setup? If you have low compression pistons what kind of cams are you looking for and why? I'm choosing cams for my new setup and need advice on how to pick out my cams. I've heard a lot of people making great power on just the stock gsr cams. Wonder if getting different ones are necessary.
Old Oct 11, 2010 | 10:06 AM
kyden's Avatar
Default Re: How do u decide on cams?
need more info on your setup.
Old Oct 11, 2010 | 10:21 AM
norcalB18's Avatar
Alright.
Block
81.5mm 8.8/1 compression
eagle rods
acl bearings
Head
Skunk 2 valve train
Skunk 2 intake manifold
Log manifold (upgrading to shortys later)
Turbo
Still undecided on which i might get but looking into the sc61
Power band looking to get good mid-top. Not alright mid and CRAZY top!
Old Oct 11, 2010 | 10:23 AM
NLR808's Avatar
Theirs a dyno comparison between a bunch of cams that helped me decide
Old Oct 11, 2010 | 10:29 AM
Turbo-LS's Avatar
Sounds like a basic mild built setup. Dependig on turbo and manifold and intake manifold is what cams u will run. Larger turbos and higher flowing manifolds will allow for more rpm and the head will require a cam to keep the torque longer
Basically you can't go wrong with a set or itr or ctr cams. Gera will get the job done but itr/ctr will make more top end with oem reliability. After that you tart getting into mild to wild cams. If it's a street car stick with oem or some skunk2 tuner 1's
Old Oct 11, 2010 | 11:18 AM
norcalB18's Avatar
THanks a bunch for the advice. Going to go look at the dyno comparisons right now.
Old Oct 11, 2010 | 11:57 PM
NLR808's Avatar
i chose blox type b's after some research and the price was right
bluemanic15601
Dec 2, 2011 06:41 AM
WhiteEJCoupe
Feb 24, 2011 09:29 AM
golf-mk3
Aug 25, 2010 04:51 PM
sharkey65a
Jan 7, 2003 12:55 PM
eg_hybrid
Apr 30, 2001 12:20 PM
