how do i turn my boost up on an oem turbo car?
How do I turn my boost up on my oem car with out any type of electric boost controler. I see my friend always turns his boost up by spinning something on his turbo.
Re: how do i turn my boost up on an oem turbo car? (E36 Fan)
your friend used(from how you explained it) a manual bleeder style boost controller....
they are cheap and work decently well... but you have to get out and change it...
search MBC, companies make them.....or you can make one yourself....
with my MBC (y7/z6 mini, 14B @ 10psi) I had to put a check valve in line with it becuase when i would bleed off boost, it would create a vacuum leak and make the car idle erratically.
just something to keep in mind.. the 14B turbo doesnt have a wastegate "out" on the compressor housing, the wastegate is hooked up to a normal engine vacuum line.
Haleiwa-Brando
10-04-2004 08:21 AM
