hondata problems and ????????
Old Apr 17, 2004 | 08:15 PM
B18C1CYA's Avatar
Default hondata problems and ????????
well i just put in my s100/ boost in my car. the ecu is a p72 obd1. well heres the problem first i took the cover off the ecu, to check the status of the led. it dosnt light up at when you turn the key on. so i started the car and it ran, it ran pritty good, but i have a cel on also. then i go to pull the codes and i cant the light just stays solid. i would like any input on this problem here if it the ecu or the base map or hondata unit? i an running a 3 bar and 450's right now and thats what the base is for, and i have not drove it yet so i dont know what it will do or wount do.please any help whould be super this thing is driving me crazy.
Old Apr 17, 2004 | 09:00 PM
Silverbeast's Avatar
Default Re: hondata problems and ???????? (B18C1CYA)
If the redlight is not illuminated on the S100, then it's not inserted correctly in the ECU. Which would make the car run a lot like **** and put the ECU in limp mode.
TokuiAutowerks
Dec 13, 2004 07:29 PM
b20izzle
Dec 7, 2004 08:42 AM
b20izzle
Dec 6, 2004 09:22 AM
busakiller
Aug 14, 2004 07:33 AM
