Holset setup?
Old Dec 28, 2008 | 02:44 PM
Silvertc's Avatar
Default Holset setup?
I have a 4 bolt Turbo Manifold for my B16. I would like to do a Holset turbo, I want to run the HY35 holset turbo, is there any adapter plate i need to run or will it bolt right up? any other advice of information let me know thanks!
Old Dec 28, 2008 | 02:54 PM
sLoWnStEaDy's Avatar
Default Re: Holset setup?
the HY35 uses a T3 flange. so if you have a T3 flanged manifold you are good, otherwise you can get a T4/T3 adapter pretty cheap
Old Dec 28, 2008 | 04:05 PM
Garage 808 Hatch's Avatar
you need to know what flange the manifold is. 4 bolt?? almost all turbos mount with 4 bolts, so that is useless. need to know if its t3, t4, t6, evo, 14b/16g, t25, etc
Old Dec 28, 2008 | 11:51 PM
Silvertc's Avatar
i have a t3 manifold. Also will i be ok with a 38MM waste gate or do i need ot go bigger?
Old Dec 29, 2008 | 08:17 AM
TTT's Avatar
TTT
The Hy35 holset has a bolt pattern that is T3 inlet. The inlet does not exactly mathc up, but nothing some port matching would not fix.
Old Dec 29, 2008 | 08:29 AM
Silvertc's Avatar
ok thanks man, does anyone know if i will be ok running 15-20 PSI on this turbo with a 38 MM waste gate or will i need a bigger waste gate?
Old Dec 29, 2008 | 08:33 AM
tony413's Avatar
ur gate is fine
Old Dec 29, 2008 | 09:54 PM
Silvertc's Avatar
Originally Posted by tony413
ur gate is fine
ok i just read some people had boost spike/creep, so i wasn't sure
Old Dec 29, 2008 | 10:56 PM
tony413's Avatar
theres other issues that cause spikes and creep besides wg sizing
EK k kay
Sep 30, 2005 01:51 PM
integramic
Feb 24, 2004 03:59 AM
EV1L SI
Jul 13, 2003 11:12 AM
smslude
May 2, 2003 02:01 PM
Bontke
Jan 28, 2003 05:15 PM
