air filters
Old Dec 29, 2008 | 01:11 AM
nothing_shocking's Avatar
Default air filters
i have a small amount of room to work with and i was wondering if anyone knew where to get some small air filters. i have about 1.5 inches between my turbo and my waste gate so i need something that can fit with that.
Old Dec 29, 2008 | 10:45 AM
redlsvtec4door's Avatar
Default Re: air filters
wow 1.5 inches. thats not that much. can we get a picture of the setup?
id just run a screen with a t bolt clamp around it. the set up will cost lest that 15 bucks and prevent larger objects but not micron objects.
Old Dec 29, 2008 | 10:52 AM
ReDemoN's Avatar
DixielandImports Please
Autozone has these new smaller air filters.
There like 20 bucks and very nice.
Might not be small enough for you though.
Old Dec 29, 2008 | 11:26 AM
ABK's Avatar
ABK
I personally always try to put a filter on, but if you have that much room you are pretty much screwed. Shows us a picture, might be able to help.
Old Dec 29, 2008 | 11:49 AM
HiProfile's Avatar
K & N makes lots of sizes, but I think that will be way too tight for any. You need to provide inlet diameter and a pic of the setup, otherwise look at these two lists:
http://www.knfilters.com/search/univround.aspx
http://www.knfilters.com/search/univcone.aspx
Old Dec 29, 2008 | 04:49 PM
flangemastermike's Avatar
just check the filter , and then double check , is it goin to fall to bits ? any metal caps that could come off ... only saying as my filter did just that 2 nights ago, shiny new garrett turbo is not so shiny now .
dont skimp out on a cheap filter. lesson learned the hard way.
Old Dec 29, 2008 | 11:48 PM
what i have on it now is something like redls said and what i was thinking about doing was just cutting out a piece of a fram filter and putting it on the outside of the wire mesh. the only thing i see that might be a problem is the heat. i don't want to be boosting and have the filter catch on fire...
Old Dec 29, 2008 | 11:59 PM
also, from the first list hiprofile posted, i think part number RU-2760 would fit just fine, only down side is that its $30... cheaper then a rebuild kit i suppose though
Old Dec 30, 2008 | 12:07 AM
SD_Lurker's Avatar
HT White Ops
A filter as small as your wanting is going to be a huge restriction. Also, that one you mentioned is 2 inches which is obviously not 1.5
rawkus
11
Nov 1, 2007 10:39 AM
Turbo Dan
Aug 2, 2006 05:48 AM
dannydos
Jun 26, 2005 06:50 AM
turbosi03
Jun 18, 2005 05:36 AM
xstalkrx
Mar 21, 2003 01:00 PM
