High/low boost setup!
Old Feb 15, 2012 | 04:11 PM
JDMCIVIC919's Avatar
Default High/low boost setup!
Im building my ls vtec now for boost. Aiming for 500+ daily. How do u do a high/low boost setups? I dont want to be running 500whp daily. Im going to be tuned on ectune. If i get the greddy profec b boost controller can i do high low boost on that?
Old Feb 15, 2012 | 04:26 PM
Garage 808 Hatch's Avatar
Default Re: High/low boost setup!
Turbo Smart manual dual stage boost controller. high/low boost changes with the flip of a switch
Old Feb 15, 2012 | 05:34 PM
DirtyDA9's Avatar
At first you say "Aiming for 500+ daily". Then you say "I do not want to be running 500whp daily."... So which is it?
I really hope you are sleeving the block. Especially if your dailying it those stock sleeves will take a ****.
Old Feb 15, 2012 | 05:59 PM
LightningTeg's Avatar
Community Builder
MAC solenoid through ectune. You can have boost by gear on a high and low switch of your choosing. Very easy to wire up.
For example you can have a total of 3.
Wastegate (EBC off)
EBC on Low
EBC on High
Old Feb 16, 2012 | 08:37 AM
I got the block darton sleeved. I just dont want to be rolling around at 500whp i only want that much when i go to the track. I want like high 300 low 400 daily. I might get that dual stage turbosmart looks good. But for $200+ i can get a greddy profec b for the same price so what would be better?
Old Feb 16, 2012 | 09:09 AM
kbouchard1092's Avatar
I also use boost by gear thru Hondata S300. I have a switch wired up for low/high boost maps that has setting for gear/RPm for both high and low boost. The swtich simplys changes the maps for the EBC
Old Feb 16, 2012 | 09:36 AM
joppe's Avatar
Get solenoid and boost control components and boost by gear via ectune, works great. Mine is 1 12psi 2 15psi rest 27psi.
Old Feb 16, 2012 | 05:15 PM
ek9+eg6=me's Avatar
my buddys t1 tuned lsvtec 360whp 1st 7 2nd 10 3rd 15 4th 15 5th 7 235/50/15 on front breaks alitle loose in third not bad though,hope this helps
Old Feb 16, 2012 | 05:36 PM
SiRCiviC94's Avatar
a 2timer and a boost controller I think is what I would think to do. flip the switch for the 500+hp tune. its come a long way tho with the hondata boost by gear is awesome
Old Feb 16, 2012 | 07:14 PM
Community Builder
For $< 40 you can just do what I said...
Old Feb 16, 2012 | 07:35 PM
Divers's Avatar
Mac soleniod controlled via ectune. Its a no-brainer. Plus, you can install it in the car in less then 20minutes and not have to wire anything.
Old Feb 17, 2012 | 05:22 AM
How does the mac soleniod work?
Old Feb 17, 2012 | 05:33 AM
Tootsie7944's Avatar
Honestly, unless your winding out gears, running 300 hp vs 500 hp on the street is the same thing. I have a high/low boost setup on my R....basically have never touched it..just leave it full blast and it drives just fine.
Old Feb 17, 2012 | 05:37 AM
PWM Electronic Boost Solenoid the same thing as MAC?
Old Feb 17, 2012 | 10:54 AM
92frostwhtdb2's Avatar
keep your right foot off the pedal, best boost controller out!
Sep 1, 2010 12:59 PM
RobbieG35
Jul 4, 2006 04:42 AM
all go teg
Aug 5, 2005 04:56 AM
adictionbass
Dec 28, 2004 10:30 AM
Jared
Sep 25, 2002 12:11 PM
