12:1 compression turbo?
Old Feb 28, 2007 | 06:20 PM
CXtypeR's Avatar
Default 12:1 compression turbo?
anybody here running 12:1 compression with turbo?
can this kind of setup actually be streetable and reliable? if the tune is the bestest of the best, is it worth doing?
Old Feb 28, 2007 | 06:27 PM
Cyphear's Avatar
you are approaching an all motor car at that point. with pump gas you will only be able to run like 5lbs.
some other people will disagree, but i do have a point.
Old Feb 28, 2007 | 06:28 PM
B18C1CYA's Avatar
Default Re: 12:1 compression turbo? (CXtypeR)
get your self a good tunner I wouls say probly around 5psi or so on pump gas , but it should hardly take any boost to make some solid numbers .
Old Feb 28, 2007 | 06:40 PM
CXtypeR's Avatar
Default Re: 12:1 compression turbo? (B18C1CYA)
5psi max on 93octane?
how would a 11:1 @ 8lbs compare to a 12:1 @ 5lbs?
can somebody explain why you need to lower the boost the higher you go in compression?
Old Feb 28, 2007 | 06:42 PM
B18C1CYA's Avatar
when you add forced induction to a motor is it just like uping your compression ratio , and the more psi you run the higher your cr will be ,
Old Feb 28, 2007 | 07:00 PM
b18sihatch's Avatar
the compression is too high
you need to have like at least the 10s to have a decent turbo setup with high compression turbo setup
the 12s are too much for turbo application boost pressure will be real low, and tuning will be a BITCH, you will need alot of tuning and detonation will definitly be something you should look out for with that high of compression
i wouldnt run anymore than 9s compression ratios with turbo application if higher compressionh is needed i wouldnt go higher than 10:1
Old Feb 28, 2007 | 07:13 PM
ninesecrx's Avatar
Default Re: 12:1 compression turbo? (b18sihatch)
Run the car on alcohol and you will be fine to boost what you want
Old Feb 28, 2007 | 07:37 PM
nihad's Avatar
why run high compression pistons
Old Feb 28, 2007 | 08:12 PM
building boost's Avatar
if you have to do it, it can be done. i don't know why the people above me limited you to only 5 psi lol. 5 psi on a t25 or 5 psi on a gt42r? 2 totally different stories, and since you haven't mentioned your turbo size we don't know what 5 psi will do for you. . . yea depends on the tuner. there is very little room for error and i recommend a thick headgasket and some alky injection. if c16 or e85 are available to you, i recommend them before you up the boost. no i don't think anyone would recommend 12:1 compression. it's better to be safer with lower compression with forced induction. 10:1 is gettin fairly common but 12:1 is very risky. a bad batch of gas could lead to detonation. good luck.
Old Feb 28, 2007 | 08:38 PM
siracerdude's Avatar
Default Re: (building boost)
thats a all motor setup you can use nitrous on race gas with proper tuning
Old Feb 28, 2007 | 10:04 PM
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXtypeR &raquo;</TD></TR><TR><TD CLASS="quote">anybody here running 12:1 compression with turbo?
can this kind of setup actually be streetable and reliable? if the tune is the bestest of the best, is it worth doing?</TD></TR></TABLE>
i wouldnt run that high of a CR with a turbo in extreme case i might run 11.0:1 with about 7psi to 11psi reasons:
1. tuning is the key and i could still drive it on the street and IDLE ok
2. when the turbos not boost i had the great all motor benfits from the high CR
3. less chance of detenation lets remember detenation is cause from heat so if i keep heat in check im good.
there are more reasons why i would run 11:1 but those are my mains
Old Feb 28, 2007 | 10:32 PM
Astig's Avatar
Default Re: 12:1 compression turbo? (ninesecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx &raquo;</TD></TR><TR><TD CLASS="quote">Run the car on alcohol and you will be fine to boost what you want </TD></TR></TABLE>
Hehe
*RINGRING*
fillerup with Alcohol, Bob!
Old Feb 28, 2007 | 10:44 PM
tony413's Avatar
Default Re: 12:1 compression turbo? (Astig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Astig &raquo;</TD></TR><TR><TD CLASS="quote">
Hehe
*RINGRING*
fillerup with Alcohol, Bob!</TD></TR></TABLE>
LMFAO how did i miss that one ROLF
henchie
Mar 28, 2016 07:20 AM
93delslow315
May 13, 2010 10:57 PM
RGSH22ACCORD
Jun 30, 2007 08:05 PM
LSEGHATCH
Oct 6, 2004 07:44 PM
MUGENTYPER
Feb 6, 2002 06:31 AM
