hf/evo8 16g plate
hf/evo8 16g plate
anyone got pics of their adapter plate to put an evo8 16g on an hf mani? i searched as best i could, came up short. can get that turbo cheap to compliment my cheap project. any help would be appreciated.
Re: hf/evo8 16g plate (bch5428)
assuming the evo8 16g's are the same as the older style 16g's, they're flanged the same as a 14b; so a hf to 14b adapter should work.
hmm, i just remembered that the evo's use "twin scroll" turbos, so they could be flanged differently.
Re: hf/evo8 16g plate (JSpin)
yeah the turbine intake is divided, i was hoping to see an example of someones work to get an idea of how everything works.
Moderator in Chief
Heres some pictures I found. Looks like he modified an Evo manifold.
https://honda-tech.com/zerothread?id=1038659
Oh and I found this little treasure while searching. Its almost as fast as my Evo in GT4
https://honda-tech.com/zerothread?id=895688
an evo 16g sits opposite of the dsm/evo1-3 16g's, when you look at the exhaust housing on teh turbo its doesnt even resemble a normal 16g, so you wont be able to use a 14b braket.
Re: (ITSME4G63)
im curious as to if honda guys using this turbo need to machine the adapter plate around the "twin scroll divider" section, or if i can just cut a hole around the entire turbine entry. i dont have a pic handy but the evo8 16g has two trapazoidial (is that a word?) ports on the turbine side for quicker spool times. so should i match the gasket exactly or just cut it wide open? id like to make it spool efficiently as possible, especially putting it on a mucher smaller motor than a 4g63. i plan to use it on a d16a6.
blinger
03-09-2007 03:11 PM
