Hey, whats this part on the turbo for?
Re: Hey, whats this part on the turbo for? (b18tdelsol)
It's a boost source, you can plug it if you don't need it, alot of people use it to run to the wastegate, or for an electronic boost controller. Personally I use a boost source after the throttle body.
Re: Hey, whats this part on the turbo for? (BG Boost)
some boost controlers require a vacum source before the throttle body. If you have one that does, use this. If not, just plug it.....Mike
Re: Hey, whats this part on the turbo for? (ninesecrx)
I had an AVC-R, and for some reason I was getting a better boost repsonse by using the intake manifold for the source than the boost source on the compressor housing...
so I plugged it up, some EBC are different though, try both, see which one you like..IMO
Re: Hey, whats this part on the turbo for? (Flamenco-t)
Hook a gauge up to that, and one to manifold pressure and you'll be able to see how much pressure loss you're getting after the i/c.
[Modified by inspyral, 1:10 AM 5/28/2002]
1 Post
Re: Hey, whats this part on the turbo for? (HXMan)
yeah, that was what i was wondering also..and plug will do right? as long as it threads in..
I tried to hook my wastegate pressure line after the throttle body, and it resulted in horrible surging. Even after softening up the spring on my BOV i still got at least one cheeeee cheeeeee before it vented. Dont know if this is relevent to everyone else. I've still got an internal wastegate so that might make some difference in the reaction time.
1 Post
Re: Hey, whats this part on the turbo for? (int3gra)
Where can I get a plug for that hole??
Wrigleys Chewing Gum
yea neway, just go to kragen and buy a fitting for it. Bring the whole turbo inside the store and show it off while attempiting to fit every screw/plug in the store on your nice turbo.
I would use that connection for the WG instead of a connection at the TB.
The smaller distance will give better response because there will be less expansion in the line.
This is assuming your using a maual boost controller. Electrics may need the TB vaccum source.
1 Post
Re: Hey, whats this part on the turbo for? (intekragsr)
Edit: it needs a good polish first
[Modified by tonydatyga, 4:22 PM 5/31/2002]
underpressure02
10-06-2003 08:14 AM
