help stripped oil pan nut
Old Jun 16, 2003 | 12:58 PM
linx's Avatar
Default help stripped oil pan nut
Help I stripped the nut that holds the oilpan to the engine.The worst part its near the transmision. The nut just seams to turn on the stud so i am unable to tighten it or lossen it. I was thinking of using a dremel to cut it off but what bit can i use that will fit in there, or any other suggestions would be appreciated thanks.
Old Jun 16, 2003 | 01:12 PM
madman604's Avatar
Default Re: help stripped oil pan nut (linx)
most likely you stripped the pan, not the nut. new oil pan time or drill and weld a new bung onto it.
EDIT: oops read it wrong...
drill a tiny pilot hole into the hole and get a bolt extractor on it. put a little honda bond in that area if you cant get a new bolt into there.
Old Jun 16, 2003 | 01:22 PM
linx's Avatar
Default Re: help stripped oil pan nut (Turbo E)
sorry if I was unclear I'm not talking about the oil drain. i'm taking about the nut that holds the oilpan to the block.
Old Jun 16, 2003 | 01:29 PM
turbo Si's Avatar
See if you can take the stud out with a vice grip, and put a bolt. If the hole is stripped then try to put a little longer bolt. Hope this helps!
liquidx
Aug 8, 2010 03:58 PM
Spithead051
Dec 17, 2008 03:53 PM
budget
May 24, 2005 07:35 AM
Blaze45
May 18, 2003 10:53 AM
ek_will
12
Feb 16, 2003 11:21 AM
