building head?
Old Feb 24, 2007 | 08:31 PM
CeeJayy's Avatar
Default building head?
i have a b16a2 currently and am going to build a gsr block forturbo on the side while i am using my b16 for dd. i am wondering what can i do to the head to make power increase and still be good after i swap blocks? vavle springs? cams?
thanks in advance
Old Feb 25, 2007 | 11:08 AM
Garage 808 Hatch's Avatar
springs/retainers, gsr cams would be fine, and deburr the head like a type R, get ti checked for valve sealing, and straightness, etc.
Old Feb 25, 2007 | 11:22 AM
zexxbo's Avatar
Default Re: (Garage 808 Hatch)
springs and retainers wont add power, but they will let you use the power that youre making until higher rpms and its always a good idea in case you miss shift or powershift. gsr cams will be good for a turbo set up, or itr cams if you can get your hands on them for relatively cheap ($300&gt. you can port and polish the head if you have the money and think its neccessary as better flow never hurts anyone. biggest things are cams, cam gears, and intake manifold really.
Xemu
Jan 2, 2010 04:57 PM
mushroom281
Jul 12, 2007 07:13 AM
Jdelsolb16T
Feb 8, 2006 03:03 PM
LBR92DA-T
Feb 24, 2004 10:28 AM
