Help: Oil return line setup, good or bad?
Old 08-14-2006, 05:37 PM
btech's Avatar
Default Help: Oil return line setup, good or bad?
Return line down from the Turbo
Down from the turbo, travel across intercooler and moves up a lil bit, then to oil pan.
Would this be the reason why my Turbo need a new seal? Is the line a little way too long?
Old 08-14-2006, 05:38 PM
Dartanian's Avatar
Default Re: Help: Oil return line setup, good or bad? (btech)
No good. The oil is gravity fed, so it is just pooling up where it goes back up.
Old 08-14-2006, 06:06 PM
planeman01's Avatar
shorter and no uphill...
Old 08-14-2006, 09:59 PM
turbotime's Avatar
no good...
may need to retap the pan, current location looks too far from turbo or try a shorter line...
Old 08-15-2006, 02:03 PM
btech's Avatar
Default Re: (turbotime)
so could this cause my an oil seal leak?
Old 08-15-2006, 04:27 PM
TurdBlown Teg's Avatar
yea that is why you have an oil seal leak because oil isnt draing into your oil pan and is just pooling up in your turbo. cut the line and tap it in front of the oil pan as high as you can get it.
Old 08-15-2006, 04:29 PM
komat's Avatar
Default Re: (kevin716)
better pictures of the line would help too. you ca nbarely see where the lijne is running from
Old 08-15-2006, 05:01 PM
planeman01's Avatar
since oil isn't draining properly, its backing up in the line and blowing out the seals on the turbo
Old 06-16-2007, 03:14 PM
racin jasin R's Avatar
Default Re: (planeman01)
would this cause your car to smoke more????
Old 06-16-2007, 03:15 PM
I tell doctors what to do
ILcrxsi1's Avatar
Default Re: (racin jasin R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racin jasin R &raquo;</TD></TR><TR><TD CLASS="quote">would this cause your car to smoke more????</TD></TR></TABLE>yes
Old 06-16-2007, 03:48 PM
Default Re: (ILcrxsi1)
thanks
Old 06-16-2007, 07:17 PM
HiProfile's Avatar
I've had a oil return that was just as 'horizontal', although it probably used half as much line. 'Bad line' + old turbo + 1/16" inlet restrictor = zero smoke. It likely would cause smoke/oil seapage if you had no restrictor and/or the turbo was already ****.
jprelude92
08-30-2008 07:12 AM
civictypenos
07-18-2005 01:54 PM
r1lorenzini
02-14-2004 05:04 PM
iperez
01-18-2003 04:36 PM
b00stedsi
07-28-2002 04:17 PM
Quick Reply: Help: Oil return line setup, good or bad?
