Turbo is leaking oil from DP
I just installed a t3 turbo that a buddy gave me to use and when i went to start it up, after about 2-3 minutes oil started dripping like crazy out of the DP side. Checked drain line for kinks and no kinks. What caused this and is the turbo shot?
Re: Turbo is leaking oil from DP (dustin)
Cant be the return line, completly took off the return line so oil can drip into a pan and it was draining fine and oil still came out of DP side.
Will a rebuild kit fix this?
Re: Turbo is leaking oil from DP (flyazzcivic)
Maybe but you have to have the turbo balanced after taking the wheels off.
Might be cheaper to just buy something like this:
http://store.yahoo.com/cheaptu....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyazzcivic »</TD></TR><TR><TD CLASS="quote">Cant be the return line, completly took off the return line so oil can drip into a pan and it was draining fine and oil still came out of DP side.
Will a rebuild kit fix this?</TD></TR></TABLE>
if for sure that is your problem.. you can send in your turbo to have it rebuilt.. (same website dustin sent you)
Elite Hatch
10-20-2002 05:43 AM
