HELP! misfire problems.
Old Apr 4, 2005 | 07:05 AM
vtec-adykt's Avatar
Default HELP! misfire problems.
well, i finally took my car to the track to get some time slips to see how she would do. on a stock internal engine im running a t3/t04e with 35mm wastegate set at 8lbs. fmic, hks ssqv bov, 2.5" downpipe, 2.5" crush bent exhaust piping, walbro 255l fuel pump, 450cc injectors, and uberdata with mild street tune. Since it was street tuned, i have no idea as to how much power im making. So i figured id try the track to get a ball park figure. Im not the best driver, but after a few shitty runs, i was satisfied with a 9.6 in the 1/8 mile. what would be your guess on power? oh yeah, back to the topic. on my way home i noticed that my car was making a weird "gargling" sound that it hadn't made before. i kept driving, then it went away. then the next day, it would only make that sound on low rpms while street cruising. Its a misfire. But i need help as to where to begin my quest to fix this problem. What would be the main problem for a misfire only at low rpms, or while in vacuum. I hit the boost side once to see if maybe it was just my wastegate being stuck open, but it boosts fine. how can i diagnose this problem to see if thats what it really is? why else would it gargle like that occasionally? thanks
Old Apr 4, 2005 | 07:11 AM
beepy's Avatar
Default Re: HELP! misfire problems. (lazyeyez)
Have you inspected your spark plugs? I end up replacing my NGK's half as often as I change my oil because hard driving in boost eats those puppies up fast. I had to stop using V-power plugs because the V-groove would wear away in a couple months.
Old Apr 4, 2005 | 07:12 AM
vtec-adykt's Avatar
i for got to mention that its a 95 civic coupe with b18c swap.
Old Apr 4, 2005 | 07:15 AM
vtec-adykt's Avatar
i just replaced my old ones two weeks ago with ngk. the guy who tuned my car said it would be better to run a plug one step colder than stock specs. would they wear out that fast?
Old Apr 4, 2005 | 07:17 AM
g2turbo's Avatar
you should be running a ngk 7
Old Apr 4, 2005 | 07:20 AM
vtec-adykt's Avatar
Default Re: HELP! misfire problems. (g2turbo)
will it have a 7 on the plug?
Old Apr 4, 2005 | 09:16 AM
vtec-adykt's Avatar
another thing i noticed, is that it doesnt misfire on idle, only when its in gear and moving. very weird.
sjkelly
Feb 1, 2006 11:02 PM
TurboGoKart
29
Apr 2, 2005 08:30 PM
donpeters
Jul 19, 2004 06:14 PM
BoOsTiN Dc2
Nov 21, 2003 08:12 PM
Vtec92Civic
Sep 19, 2003 05:55 PM
