My trip to the track.
I recently went to edgewater in Cincinnati, and here's my slip. Mine is boxed in red.
My 60' time sucked because I was running my Wintermaster tires, lol. But I plan to go back again with my other tires. I was running open downpipe on these runs too.
Setup:
Garrett T3 .60 trim
Lovefab shorty
Tial 35mm ext. wastegate
Type S BOV
3" dp
full 3" SS Kteller exhaust (I was running on an open downpipe that day)
RC 440's
Walbro 255 pump
Uberdata
PLX M-300
Setup:
Garrett T3 .60 trim
Lovefab shorty
Type S BOV
3" dp
RC 440's
Walbro 255 pump
Uberdata
PLX M-300
Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">Based on the reaction times in the right column, the strip wasn't running pro-tree style. Get those reaction times down and 13's won't be a problem.</TD></TR></TABLE>
Here we go again with the reaction time BS... Reaction time does not make a difference in your 1/4 mile times... You can sit there for an hour and run a 10 second pass... The 1/4 mile time clock doesnt start untill your car moves.
Anyways, if you get your 60ft times down to a 2.1 or 2.2 you should be seeing 13's no problem, mid - high's I would say.
Re: (civiccpedx)
with a trap speed of 101 u should easily be in 13's. get some nitto drag radials and a good 60 ft and u will be in mid 13's no problem. how much boost are u running?
10 psi. I just recently put my summer tires back on. 205/40/16 with cheap-0 federal tires that have a treadwear of 240 though. So we'll see what that will do.
Re: (Kendall)
Over 6000 posts, and still an idiot!
BahahahahA!
BahahahahA!
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: (Jawad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jawad »</TD></TR><TR><TD CLASS="quote">
BahahahahA!</TD></TR></TABLE>
Re: (Kendall)
....i hope ur kiddin
he has to be kiddin
anyways 60' is the key...get it down, get better tires and ur good
he has to be kiddin
Re: (Jawad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jawad »</TD></TR><TR><TD CLASS="quote">Over 6000 posts, and still an idiot!
damn, dont rip his *** up too much!!
Thats weird.. Im running a eclipse t-25 @ 10psi and stock internal d16y8 on hf manifold and stock injectors and pullin 14.24@98mph..2.4 60ft..And this is at high altitude of Colorado.
I would of thought the t3-60 would of pulled better times than that.. How does your turbo respond, cuz my little t25 looses out in 3rd gear bad...
Re: (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">stock injectors at 10 psi, wow? is that safe. u should get some dsm 450 ones</TD></TR></TABLE>
It's only a t25 though... he's probably not pushing THAT much power to overload those injectors, but yeah i'd get new injectors just to be safe.
