Help me set my profec b....
Old Nov 4, 2001 | 03:20 PM
DamonBoost's Avatar
New User
Default Help me set my profec b....
Ok I have the sharp almost all the way up and the low boost at about half way.. That allows me to have 8psi.. is that about right. I have it wired up correctly but my hose that goes into the intake manifold is on a "t" with a few other lines.. is that ok?? i am just curious if this is how far you have to turn it up to get 8psi? i have tial 35mm wastegate if that makes any difference....I am also using the top and side ports of the wastegate..Also does the high boost work off of the low boost. for instance if i leave the low boost at 8, will the high boost start from there when i start to tune it? meaning all the way down on high boost is 8psi and as i start to turn it up it goes to 9, 10, etc.. just wondering if it fed off of the low boost.. thanks for the help..
Old Nov 5, 2001 | 05:28 AM
DamonBoost's Avatar
New User
Default Re: Help me set my profec b.... (Damon501)
ttt
civic-8442-
May 21, 2008 10:35 AM
hoskos
Feb 21, 2007 06:21 AM
pip9
Sep 24, 2004 09:17 AM
integ2
Jun 15, 2004 06:44 PM
B_1_8_hatch
Oct 6, 2003 12:01 AM
