Oxygen sensor question
Old Nov 4, 2001 | 08:34 AM
GruvyTune's Avatar
New User
Default Oxygen sensor question
How do you know if the 02 sensor is working ok?
I disconnected mine when I put in my new exhaust last night and ran the car without one.
I didn't get a Check Engine Light like I though I would.
Does that mean anything? Aren't you supposed to? Could it be because I am running a Hondata unit (I thought the CELs are supposed to work the same with Hondata and that only the fuel/ignition maps are different).
Old Nov 4, 2001 | 09:32 AM
smoothludey2's Avatar
New User
Default Re: Oxygen sensor question (GruvyTune)
if the O2 sensor is not working properly then you would prolly notice...i.e. rough idle, sluggish throttle response...i would assume that OBD1 would still throw a cel for a malfunctioning O2 sensor.
Old Nov 4, 2001 | 03:51 PM
Lei Siew Long's Avatar
Default Re: Oxygen sensor question (smoothludey2)
i don't have an o2 sensor bunged on my downpipe because of the sloppy work from a wack *** shop and it idles really rough and bogs like crazy. and the check engine light does come on as well but that is with a factory ecu.
sorry to be off topic but, how do you like your hondata 3b? is it worth the extra $145 compared to the 2b? do the extra features work well like the full throttle shifting capability and especially the two stage rev limiter for launch control? i ordered a 2b and might reconsider and go with the 3b. thanks in adv
Old Nov 5, 2001 | 06:26 AM
GruvyTune's Avatar
New User
Default Re: Oxygen sensor question (boostedeg6)
i only got the 3b because with the group buy i got $100 in Dyno time so it was only another $50 for the 3 vs 2. I have not hooked in the other features. I have to mount in a bracket for the clutch switch to to make it work. I will get around to that one day but certainly after dyno tuning and chip burning this weekend!
Old Nov 5, 2001 | 07:04 AM
rtype11's Avatar
you disconneted O2 from harness or from Cat only? if only from cat your computer will show a CEL on the second driving cycle - OBDII, plus when you just start the car it sdoes not use the O2 untill car is warm - closed/open loop operation.
jeffy
Mar 21, 2008 02:36 PM
TypeRguy97
Oct 25, 2006 09:55 PM
gamakichi77
Mar 18, 2005 05:12 AM
NOSED_CRX_VTEC
Nov 7, 2004 10:04 AM
