HELP me get another beast on the streets!
Old Apr 19, 2003 | 06:33 PM
trbob16a's Avatar
Default HELP me get another beast on the streets!
I'm trying to start my car after a long, long buildup and it doesn't like me. Everything on this car was done from the ground up, so I can't really rule out any major system.
The relevant parts of the setup:
1992 honda civic CX
2000 b16a2
GSR wiring harnesses plug and play
hondata 4b
800cc injectors and resistor box (checked continuity, these are good)
The problem:
Check engine light comes on at 'ACC ON' and stays on, also the battery comes on and stays on
what I've tried/checked:
brand new battery (old one died sitting for a year)
checked all fuses engine bay and under dash
checked three engine grounds: tranny, by the heater water outlet, and valve cover
checked engine wire harnesses connections, including into the fuse box
tried a p28 hondata and the interface box wouldn't light up but CEL is always on
tried the stock cx computer just to go to 'acc on,' still solid CEL
tried a p72 with hondata ROM solid CEL
reset ecu
reburned ROM for hondata
I do get fuel pressure and fuel into the cylinders
I do not get spark
the starter tries to crank the motor
EDIT: went into the distributor and there isn't any voltage at the ICM, but all the fuses are good
Any ideas on how to fix the CEL? I couldn't get a code out of it...
Modified by trbob16a at 2:04 PM 4/20/2003
Old Apr 19, 2003 | 07:31 PM
Poop111444's Avatar
Default Re: HELP me get another beast on the streets! (trbob16a)
Distributor? Borrow a friends and see if that works
Old Apr 19, 2003 | 09:59 PM
TeStUdO's Avatar
the dissy or the ignitor is what im thinkin. good luck buddy. **** like that is a pain in the ***
Old Apr 20, 2003 | 07:24 AM
trbob16a's Avatar
Default Re: (00si5)
bump.. more ideas please
would the distributor cause it to come on solid though even if I hadn't started cranking it yet?
Old Apr 20, 2003 | 12:17 PM
TeStUdO's Avatar
have you tried to reset it and start it again? if that doesnt work try to get what the code is again
ladysman
May 27, 2005 10:03 AM
Ka chao
Sep 14, 2004 11:51 PM
FFDragger
Jul 6, 2002 02:17 PM
milf H U N T E R
Jun 26, 2002 10:34 PM
Xerxes
Aug 30, 2001 08:50 PM
