96 civic ex ?? what to do
Old Apr 20, 2003 | 08:23 AM
ASHY-ELBOW's Avatar
Default 96 civic ex ?? what to do
k i sold my teg and still have my turbo kit(b series)
i am buying a 96 ex now here is what i have to work with
i have enough to either
1.buy a ls swap and thats its ...run my kit at low boost maybe 8-10 pounds on stock ls motor
2.or keep the ex sohc vtec motor and use the money to build that motor ...trade my max manifold and dp for a d series one and call it the day?
my question is which would be faster a sohc with pistons,rods,studs maybe sleeved? or stock ls on boost?
specs on turbo are t3/t04e 57 trimm 63 ar running emanage
any opinions would be great guys especially those who are running those type of setups daily
Old Apr 20, 2003 | 10:47 AM
98civicEX's Avatar
Default Re: 96 civic ex ?? what to do (ASHY-ELBOW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ASHY-ELBOW &raquo;</TD></TR><TR><TD CLASS="quote">my question is which would be faster a sohc with pistons,rods,studs maybe sleeved? or stock ls on boost?
any opinions would be great guys especially those who are running those type of setups daily </TD></TR></TABLE>
all depends on how much boost you're going to be running...i'd say keep the ls and boost that rather then building up the SOHC.
Modified by 98civicEX at 3:47 PM 4/20/2003
Old Apr 20, 2003 | 12:14 PM
ASHY-ELBOW's Avatar
Default Re: 96 civic ex ?? what to do (98civicEX)
well on the sohc i would run as much boost as the block could handle safely
but on the ls with stock bottom end prolly around 8-10 pounds
what set up do you have and specs?
Old Apr 20, 2003 | 12:28 PM
TheShocker's Avatar
Build the **** out of the d series, it'll blow the stock low boost LS out of the water no question.
Old Apr 20, 2003 | 12:32 PM
hybridb18's Avatar
i got the exact same car with a bone stock turbo ls and i ran a 13.2 @ 107 mph. not that bad
hakkoo
Jan 11, 2006 11:08 AM
w
20
Apr 12, 2005 09:39 PM
boostin4drcivic
May 1, 2004 03:58 PM
DreamRacer
Nov 28, 2003 01:35 PM
quanx22
May 23, 2003 02:16 PM
