Help, with manual boost controller
Old Jun 2, 2006 | 01:20 PM
standbackimapro's Avatar
Default Help, with manual boost controller
my friend has a 1996 Civic with a d16, he turboed his car and he has the boost controller from the wastegate to the intake manifold
He says after he goes threw some gears he cant accelerate like he gives it gas and the motor doesnt do anything, and he says he has to turn it off and turn it back on for it to work
and he said last night he was driving and he stopped and looked at the vacumn lines and 2 of them were sucked closed
Old Jun 2, 2006 | 01:32 PM
Soccerking3000's Avatar
Default Re: Help, with manual boost controller (standbackimapro)
what are you asking? the description is really vague, be more specific
Old Jun 4, 2006 | 12:46 PM
Why after he goes threw a few gears, does he loose throttle
And why do some of the vacumn lines pinch in ..
Old Jun 4, 2006 | 01:00 PM
Default Re: (standbackimapro)
uhhh what is his engine management? i bet he is getting a CEL and the ecu is going into limp mode
Old Jun 4, 2006 | 02:04 PM
VTteg's Avatar
Default Re: (Soccerking3000)
Is he using those cheap thin walled silicone lines? If so, go get some beefier vacuum lines.
Old Jun 4, 2006 | 02:16 PM
QwkD16's Avatar
I bet one of the vac. lines is goin to the MAP sensor, but why did you set this question up about the boost controller?
Old Jun 4, 2006 | 03:35 PM
Default Re: (QwkD16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QwkD16 &raquo;</TD></TR><TR><TD CLASS="quote">I bet one of the vac. lines is goin to the MAP sensor, but why did you set this question up about the boost controller?</TD></TR></TABLE>
if its a stock map which i bet it is, there is no vacuum line going to it...
Old Jun 4, 2006 | 03:37 PM
hondaeg8's Avatar
i think you can just Tee it off to the vacum line that is going from the side of the WG to the intake manifold.
Old Jun 4, 2006 | 03:39 PM
Default Re: (hondaeg8)
and it would be nice if you told us which vacuum lines collapsed...
ericstambaugh07
Apr 7, 2007 12:45 PM
standbackimapro
May 30, 2006 05:22 AM
SpoolnByYou
Feb 24, 2006 07:19 PM
importboi22
May 20, 2004 04:43 AM
X2BOARD
Dec 16, 2001 10:54 PM
