darton sleeve leak fix
Old Feb 19, 2010 | 07:29 PM
oneson1985jim's Avatar
TRIAL USER
Default darton sleeve leak fix
Ive just bought a darton sleeved gsr block with a leak into the oil pan. Apparently the o ring in one of the cylinders has failed. thats what the shop said that had it last. Is there a replacement o ring kit? Do you use the new epoxy sealer they offer? Also, if the o rings can be replaced, can any machine shop replace them or should i send it back to darton? Where can i find these o rings if they can be bought. Is there any other method to remove this leak that anyone has had success with? thanks for the help
Old Feb 19, 2010 | 11:06 PM
TRIAL USER
Default Re: darton sleeve leak fix
bump lol i need help. somone has to have input.
Old Feb 20, 2010 | 08:15 AM
TRIAL USER
anyone. ive never seen a thread on this. kets get some inpput here
Old Feb 20, 2010 | 09:25 AM
90blackcrx's Avatar
I'm not sure about darton sleeves, but if its anything like golden eagle you can tap the o-ring in by yourself. I know golden eagle sells the copper material. Here is a link to the golden eagle type, hopefully it helps, if its not the same disregard.
http://www.goldeneaglemfg.com/includ...INGINSTALL.pdf
http://www.goldeneaglemfg.com/index....hj9i6hfvii2sc0
Old Feb 20, 2010 | 09:40 AM
non-VTEC's Avatar
i think he is referring to the o-ring seals at the bottom of the sleeves on the darton MID kit.
it's not a simple "pop in the new seal" and your done. it's a big job to replace those seals and will require a total new bore/hone/machine/re-assembly and leak/pressure check to make sure it's all good.
take it to an authorized darton sleeve install machine shop and have them check it out for you.
Old Feb 21, 2010 | 03:36 PM
Crash88's Avatar
Whattzzzz Up Whatkind of leak , oil , air , water ? First of all find out why the ring popped out . There may be other problems below the surface. Maybe the sleeve,s are floating or engine was over heated and disformed.
94civicgsr
Feb 11, 2013 07:45 PM
crxhf19
Feb 22, 2005 03:16 PM
C-Murdock
Dec 17, 2002 06:37 PM
ProjectMurder
Sep 25, 2002 05:38 AM
