Help installing RC injectors!!! ASAP
Old Nov 23, 2003 | 11:58 AM
Toda Built's Avatar
Default Help installing RC injectors!!! ASAP
I trying to install my RC's right now, and I cant get them to fit into my intake manifold. ('96 GSR) Do I leave my stock bottom O-ring in the intake manifold and use the O-ring that came on the bottom of the injector at the same time. Or do I take out the stock O-ring and just use the O-ring that came with the injectors
Old Nov 23, 2003 | 12:01 PM
HXMan's Avatar
Default Re: Help installing RC injectors!!! ASAP (SH_LUDER)
The instructions say to remove the stock o ring, and install the one provided with the injectors.
The injector won't bottom out, but will seal properly once the fuel rail is tightened down.
Old Nov 23, 2003 | 12:07 PM
Toda Built's Avatar
Default Re: Help installing RC injectors!!! ASAP (HXMan)
Thanks for your help man...
One more question. None of the wire colors on the RC's match the wires on my stock wiring harnes.
I dont have the instructions cause I bought them used. Does any one have a pic of the wiring diagram Thanks
Old Nov 23, 2003 | 12:19 PM
t04ecvc's Avatar
Your RC's came with a harness? The ones I got were just plug and play. Just install them like your stock ones and you should be ok.
postman
Apr 24, 2008 02:11 PM
blakacintegra
May 22, 2007 09:18 PM
95gsr
Mar 3, 2004 04:50 AM
5gen-hybrid
Jan 13, 2002 10:45 PM
