install of rc 440 sat. injectors??
I have a question. I am about to install my injectors and i noticed that if I use my injector seals the seal becomes to large for the injector to fit into the stock fuel rail. Am I suppose to get differant seals or something. turning my head thanks again
Luis 95 gsr
Luis 95 gsr
Re: install of rc 440 sat. injectors?? (95gsr)
I either use a tapered injector grommet or bore out the inside of the stock gromment and spacer.
The tapered grommet places the injector slightly further back.
I'm not sure where to get the tapered ones from b/c I got them with the injectors I bought used.
Will you make something up for me please?
Just trim a little material off the inside of the grommet. It'll be fine. That's what I did, I had the same problem.
hayabusa160
08-10-2004 09:42 PM
