Help on D16 Turbo Timing
Old Jun 27, 2002 | 08:14 AM
spike's Avatar
Default Help on D16 Turbo Timing
I'm putting a t3 on a d16z6.. and i'm doing Liam's hack with the AFC to run 450's and no check valve.. I wanted to know if I have to get BTM or can i run stock ignition.. most people seem to run stock ignitions. But how much do i retard the ignition, and it won't be able to retard the ignition more per pound of boost correct?? Any tuning tips would help. I'm hoping to run around 10 psi when completed.
Old Jun 27, 2002 | 08:49 AM
Hayasa15's Avatar
Default Re: Help on D16 Turbo Timing (spike)
do a search. but i am pretty sure you retard the stock ignition but a btm or standalone would be the better way to go.
Old Jun 27, 2002 | 08:55 AM
spike's Avatar
I have.. and many people say retard the timing .25 degrees per pound of boost.. but if it doesn't depend on boost won't retarding it 2.5 degrees from idle be bad?.. there's no easy way to make it react to boost other than a BTM .. i'm looking for something cheaper. What if I just used a ton of fuel to start off and no retardation.. then tuned down the fuel from there?
Old Jun 27, 2002 | 09:26 AM
ion_four's Avatar
the stock timing is 16º+-2º, so if you retard it two degrees to 14 BTDC you won't be loosing THAT much power out of boost...
Old Jun 27, 2002 | 09:28 AM
spike's Avatar
Default Re: Help on D16 Turbo Timing (ion_four)
excellent.. thanks a lot man.. what would I need to do to run 15 pounds of boost? Rods? Pistons? GM 3 bar MAP? I'm not too good with my honda's yet.. still learning.. thanks for the help guys!
Old Jun 27, 2002 | 10:57 AM
genop's Avatar
You wont be able to run 15 psi with the afc because your stock ECU will start to see boost at around 10-11 psi (I think) and you will throw a code.....might want to go with standalone if you want to go that high.
I'm not really sure what affect the 3 bar sensor would have with the afc....
[Modified by genop, 7:59 PM 6/27/2002]
Old Jun 27, 2002 | 11:00 AM
spike's Avatar
Default Re: Help on D16 Turbo Timing (genop)
Isn't there anyway to get around that? I'm looking for a cheap way to run more boost .
bnmm
Engine Management and Tuning
Jan 29, 2011 02:52 PM
VspecSiR
Apr 30, 2004 10:47 PM
Licensed2Spool
Apr 9, 2003 06:22 AM
808eg6
Jun 24, 2002 07:52 AM
LudeSi-93
Jun 21, 2001 07:46 PM
