Help with custom boost controller !!
Old Jul 20, 2006 | 05:45 PM
Offer's Avatar
Default Help with custom boost controller !!
Hey what's up, i'm tryin to set up a MBC for my edelbrock kit on my d16y8. Now i saw on some site where they explained How to make a MBC , they talked about using an air pressure regulator, which is basically the same thing (spring on the inside-turn in to increse the tension and turn out to decrease the tension, now my dad is a plumber, and he brought me a nice regulator which is like the one i saw on the site.
Now i need to know if this could work, and which way i have to connect it
here are the pics:
Here is the regulator.
Now this is the bottom of the regulator, there are 4 ports which the 2 on the sides are for gauges which are blocked off, and the other 2 on top and bottom is for the lines, now the is an arrow to show the directions that the air should travel, now i need to know which side i have to connect my vaccum sourse and my wastegate actuator hose, could someone help me with this ??
Old Jul 20, 2006 | 06:04 PM
ryan89crx's Avatar
put a couple barbed nipples on it, open the valve all the way and blow through it as you turn the ****. if it doesnt get resistance, you are blowing on the wrong side
if it gets resistance, put that side on your vac source and the other side going to the WG
Old Jul 20, 2006 | 09:15 PM
Offer's Avatar
Will i get alot of spike with this ??
Old Jul 20, 2006 | 09:55 PM
ryan89crx's Avatar
Default Re: (Offer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Offer &raquo;</TD></TR><TR><TD CLASS="quote">Will i get alot of spike with this ??</TD></TR></TABLE>hard to say, all MBCs will have some spike. some more than others. firsthand experience will the only way to tell...
Old Jul 21, 2006 | 07:48 AM
BlackCRX's Avatar
im using one of those right now, no spikes at all
but then agian im using mine on an external wastegate
http://www.tialsport.com/docum...l.pdf
pataww2001
Oct 14, 2006 09:28 AM
SwIntegraB16
Jul 7, 2005 05:15 PM
integ2
Jun 15, 2004 06:44 PM
