How does a manual and electronic boost controller work, and which ones are good?
Old Jan 8, 2010 | 07:08 PM
danmej1's Avatar
Icon2 How does a manual and electronic boost controller work, and which ones are good?
I know its a really noobish question but I need to know it and I been trying to find out how they work by searching stuff here on Honda-tech and google but still no answers so please help a fellow honda-tech member out
Old Jan 8, 2010 | 09:45 PM
danmej1's Avatar
Icon2 Re: How does a manual and electronic boost controller work, and which ones are good?
bump
Old Jan 8, 2010 | 09:46 PM
danmej1's Avatar
Default Re: How does a manual and electronic boost controller work, and which ones are good?
need help please
Old Jan 8, 2010 | 09:56 PM
danmej1's Avatar
Hmm
Old Jan 9, 2010 | 08:52 AM
darkvader0's Avatar
Well normally the boost is controlled by the turbo pressure overcoming the spring in the wastegate. Once the boost pressure reaches the spring tension the wastegate valves opens and bypasses exhaust around the turbine, so boost stops climbing.
Boost controllers work by altering the amount of pressure seen by the wastegate. Manual ones just bleed off a certain amount of air before it reaches the wastegate so it "tricks" it into opening later (at higher boost).
Electronic ones do the same "trick" on the wastegate but have an electronic solenoid mechanism to have control over exactly how much pressure the wastegate "sees."
Old Jan 11, 2010 | 08:28 AM
LGK-VW's Avatar
Some good controllers can be found here.
http://www.turbosmartonline.com/inde...st-controllers
turbo sol
Feb 23, 2009 09:12 AM
MidwestAutoWorks
Jul 9, 2007 01:10 PM
avsrule414
Dec 10, 2005 09:07 AM
ek9vboi2
Jul 18, 2004 08:14 PM
Duck Sauce
Dec 6, 2001 03:36 PM
