help boost spike
Old Aug 22, 2005 | 05:29 PM
B18 rider's Avatar
Default help boost spike
Hi I have a tial 38mm wastegate with a 7 psi spring, and my boost gauge never has gone over 8 psi, but in the last week or so its been going to 10 and 11 psi, i checked the wastegate there is no leaks or anything, im just wondering what it could be, also my blow off valve has not been working unless i boost over 5 psi, the wastegate and bov are on the same vaccum line if that makes any diff.
if you have any ideas that would help please let me know
thanks
Old Aug 22, 2005 | 06:59 PM
BlueShadow's Avatar
Default Re: help boost spike (B18 rider)
Usually you want the wastegate to have it's own boost source, which can either be before the throttle plate or after it. The only other thing that should be tied to the WG's boost line is your boost controller. The BOV can share the same vacuum source as say your boost gauge, brake booster line, or maybe even your FPR line, however I dont think it's a good idea to run it to the FPR line.
Old Aug 23, 2005 | 10:16 AM
B18 rider's Avatar
cool ill try that out.
thanks man
Old Aug 23, 2005 | 12:11 PM
vaporboy12's Avatar
Default Re: (B18 rider)
more info would be great about your setup
which manifold you using
Old Aug 23, 2005 | 01:08 PM
B18 rider's Avatar
its a stock b18b with a equal lenght manifold with a tial 38mm wastegate open dump tube, 2.5 inch downpipe and 3 inch exaust.
krysted9354
May 10, 2009 11:13 AM
Makdaddynuge
Jun 4, 2006 03:46 PM
B16CRXT
Apr 24, 2005 07:50 PM
FOrSfEd
May 17, 2004 10:13 PM
20lb.teg
Sep 14, 2002 02:28 PM
