Deltagate Questions?!?!?!?!?!?
Old Sep 14, 2002 | 09:24 AM
20lb.teg's Avatar
Default Deltagate Questions?!?!?!?!?!?
Ok, so I have a Turbonetics Deltagate Mark II wastegate. (yes I know you are going to say get a TIAL, or something else but I got fucked when I bought my wastegate so this is what I have! ) But anyways, now that I'm off that little tangent... There are 2 ports on the Deltagate the top one says "vaccum" and the side one says "boost" can anyone running a deltagete tell me where these are supposed to go? Thanks,
Later,
Sean C.
Old Sep 14, 2002 | 09:42 AM
MyWhiteCivic's Avatar
Default Re: Deltagate Questions?!?!?!?!?!? (20lb.teg)
The top one doesn't hook to anything. I am pretty sure it is for atmosphere. The Side one hooks into the vacuum line which goes to your FMU or boost controller, etc. The way I have my Tial setup (same ports) is I have the side port going to my boost controller, then the vacuum line hooks into another vacuum line on my intake manifold. You can hook it anywhere that is a vacuum source.
Old Sep 14, 2002 | 09:44 AM
Danger's Avatar
if you have a boost controller with your set-up then run the line from the boost controller to the "boost" part on the wastegate , should be the top . if you do not have a boost controller then leave that part alone and the wastegate will boost up to wat its set at ( 7lb. spring , 9lb spring...watever one u got in there). but since its a deltagate that could be a bad idea . might go from 7lbs to 17lbs. . for the "vaccum" , run hose from a vaccum source to the wastegate . if you have a fitting on the outside of your turbo you can also run it from that fitting to your wastegate . just needs a vaccum line to go to it .
Old Sep 14, 2002 | 10:03 AM
Default Re: Deltagate Questions?!?!?!?!?!? (jonny5)
When I called TurboXS, they said I should leave the top port on my Tial open even though I am using the TurboXS Dual Stage MBC. I have heard that putting the line on top can cause problems... is there any truth to this?
Old Sep 14, 2002 | 10:10 AM
wickedxboi's Avatar
Default Re: Deltagate Questions?!?!?!?!?!? (MyWhiteCivic)
if i have the fitting on the top part of my tial and im not using it. will it matter? or i should take it off?
Old Sep 14, 2002 | 10:20 AM
Danger's Avatar
i have never seen any problems come up from running it that way . now 20lb.teg has 2 options on how to set it up . pick one buddy .
[Modified by jonny5, 7:22 PM 9/14/2002]
Old Sep 14, 2002 | 02:28 PM
20lb.teg's Avatar
Alright I got it and it works great, thanks a lot guys.
Later,
Sean C.
zach1288
Jul 8, 2010 02:39 PM
cacahead1
Apr 6, 2006 04:49 PM
Zach L
Mar 1, 2005 11:30 AM
.David
Jun 4, 2004 10:50 PM
gofastjdmcivic
Apr 28, 2004 04:29 AM
