help with boost gauge
Old Jul 5, 2007 | 07:45 PM
2000civic ex's Avatar
Default help with boost gauge
well i am pretty new to turbo'd cars but when my car is off it goes to zero.i know that suppose to be right. i noticed though that when i turn up the boost manually(4-8 pounds) and push it hard i barely see it go past 0 on the gauge. isn't it suppose to read like 4 psi if i put it on 4 pounds? help with reading the gauge. thanks
Old Jul 5, 2007 | 08:45 PM
Tippyman's Avatar
Default Re: help with boost gauge (hellcry)
How do you know that you really have it on 4 lbs?
Old Jul 5, 2007 | 08:47 PM
numbnuts22715's Avatar
how big is your wastegate spring?
Old Jul 6, 2007 | 02:37 AM
Default Re: (numbnuts22715)
i think it is 14psi spring. and i have a manual boost controller but i turned it 4 times from it being completely closed. because i rotation is 1 psi. so doesn't suppose to hit 4 psi when i drive it?
Old Jul 6, 2007 | 03:10 AM
Topdawgg's Avatar
if you have it set properly at 4 psi, when you STEP ON THE throttle, it should go up to 4 psi
but if you arent puttin the foot to the floor, it wont go up to the boost level you're set at...
does your gauge have vacuum also?
Old Jul 6, 2007 | 03:28 AM
Default Re: (Topdawgg)
is has vacuum i don't put it all the way to the floor i gas it till like 6rpm and it just goes at most 1psi in like 3rd gear. if i were to gas it will pass what i set it for? if it set for 4 psi can it go past that if i were to hit like close to red line? afarid of overboosting..or damaging my engine. help anyone...
Old Jul 6, 2007 | 05:58 AM
ndogg's Avatar
Default Re: (hellcry)
TAKE YOU CAR TO A TUNER RIGHT NOW or you will end up with a blown motor real soon. btw, if you have a 14psi spring in your WG, you cannot control boost at 4 psi... once you get your boost problem figured out, you will be boosting 14psi and you can most likely kiss your motor goodbye real quick once that starts happening.
Old Jul 6, 2007 | 07:51 AM
Topdawgg's Avatar
Default Re: (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">TAKE YOU CAR TO A TUNER RIGHT NOW </TD></TR></TABLE>
exactly...
if you dont put your foot to the floor, you wont boost... partial throttle it and keep it alive.. as long as you are in vacuum, no matter what RPM you are at, you arent boosting
Old Jul 7, 2007 | 09:11 AM
dpetro1's Avatar
Default Re: help with boost gauge (2000civic ex)
first, does the car have a turbocharger installed?? if yes, is it installed correctly? if no, you dont need a boost gauge.
second, if you dont know what you are doing then dont drive the car. if you dont know how the boost controller works then take it off and learn how a wastegate works first, then try again.
if you think you have everything installed correctly then you arent boosting because there is a leak somewhere, find it and fix it.
Outkast95LS
Oct 17, 2007 07:10 PM
JDM_Acccord
Aug 13, 2007 09:41 PM
CivicDude2k4
Jul 31, 2006 08:18 AM
boostdB16a
Jul 9, 2003 04:48 PM
