Boost gauge reading is off?
Old Oct 16, 2007 | 10:11 PM
Outkast95LS's Avatar
Default Boost gauge reading is off?
Weird issue that i'm having. I have a 11psi spring on my 38mm tial wg. boost gauge says 11psi. when i was tuning, my tuner said i was only boosting 6psi (i had boost gauge unhooked because i had my map sensor using the vacuum port) And i just installed my greddy profec b type 2 and it also says im boosting about 6.5psi, while my autometer boost gauge reads 11psi.
What do u guys think the issue is? boost gauge is inaccurate?
Old Oct 16, 2007 | 10:21 PM
carrnut21's Avatar
thats way off i would try and hook up another boost gauge and see what it reads
edit: if the spring is an 11 psi spring and our boost gauge reads 11 psi then it sounds like your tuner might be wrong idk thats weird
Old Oct 16, 2007 | 10:31 PM
quicksilver1689's Avatar
i ♥ snails
yeah try and use another boost guage, depends on the tuner, but most reputable tuners have alot of experience and i would trust there word. what port is the greddy profec hooked up to?
Old Oct 16, 2007 | 10:32 PM
Default Re: (carrnut21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carrnut21 &raquo;</TD></TR><TR><TD CLASS="quote">thats way off i would try and hook up another boost gauge and see what it reads
i doubt the tuner is wrong b/c my greddy profec b also says 6.5psi..
Old Oct 16, 2007 | 10:33 PM
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">yeah try and use another boost guage, depends on the tuner, but most reputable tuners have alot of experience and i would trust there word. what port is the greddy profec hooked up to?</TD></TR></TABLE>
The vacuum line is ran off to a T off the back of my intake manifold which in then is T'd off to my boost gauge. So its coming from the same source.
Old Oct 17, 2007 | 12:06 AM
i ♥ snails
hmm, did your tuner figure it was at 6.5psi from the profec, map sensor, or his own guage?
Old Oct 17, 2007 | 12:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">hmm, did your tuner figure it was at 6.5psi from the profec, map sensor, or his own guage?</TD></TR></TABLE>
Crome, which read it from the map sensor. I believe it said 6.9psi.
Old Oct 17, 2007 | 01:12 AM
BoostedEG6's Avatar
Default Re: (Outkast95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkast95LS &raquo;</TD></TR><TR><TD CLASS="quote">while my autometer boost gauge reads 11psi.</TD></TR></TABLE>
Thats your problem right there
Old Oct 17, 2007 | 03:51 AM
slowcar's Avatar
Default Re: (BoostedEG6)
my autometer gauge isn't very acurate either. I'm gonna try a vdo and see if it's any better.
Old Oct 17, 2007 | 04:08 AM
twkdCD595's Avatar
Default Re:
When the car is off, does the gauge read at the 0 mark?
I noticed on one my friend had in his blown mustang that when he would turn off the car the needle would return to like right at the 3 psi mark, ended up being off almost exactly that 3 psi when he checked it with another one. He sent it back to autometer and they recalibrated it.
I know alot of people say these gauges are not accurate, but I have not had a problem with mine and alot of people locally seem to have little issue with them besides that boost gauge. Guess we have had a good run of luck for the most part.
Old Oct 17, 2007 | 06:54 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">
Thats your problem right there</TD></TR></TABLE>
I have 2 older autometers and they are off by a few psi also.
Old Oct 17, 2007 | 10:46 AM
Default Re: Re: (twkdCD595)
Yea, when it's off, it's at the 0 psi mark. Ive never had issues before, i had a 6psi spring in there, and the gauge read 6psi, and I now have a 11psi spring, and the gauge reads 11psi. Not sure why the map sensor and the greddy profec say 6psi.
Old Oct 17, 2007 | 11:11 AM
drSquish's Avatar
Mechanical gauges seem to be more reliable than electronic sensors if they are calibrated right.
Face it your gauge is a lemon.
Old Oct 17, 2007 | 11:22 AM
Bakeoff's Avatar
So you have an 11psi spring for sure? And the gauge reads 11psi.
I would mess around with the profec for a while. Cause unless your turbo can't make more than 6.5psi, you would have to have a nast leak somewhere before the wastegate to have that happen. An 11psi spring shouldn't be able to boost less than 11psi unless there's another issue.
Old Oct 17, 2007 | 11:25 AM
i ♥ snails
new gauge ftw
Old Oct 17, 2007 | 01:52 PM
SFWD 1934's Avatar
Auto-Meter boost gauges have a tendency to be a tad off.
Jason
Old Oct 17, 2007 | 02:39 PM
Default Re: (SFWD 1934)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFWD 1934 &raquo;</TD></TR><TR><TD CLASS="quote">Auto-Meter boost gauges have a tendency to be a tad off.
Jason</TD></TR></TABLE>
A tad is like 1-2psi, not a whole 5-6psi off, right? In either case, i'll borrow my friend's gauge this weekend and see if it reads it accurately.
Old Oct 17, 2007 | 07:07 PM
SFWD 1934's Avatar
If you can, use a stainless steel line. Something that will not as much "growth" of "flex" like a rubber or plastic line like Auto-Meter supplies.
Jason
Old Oct 17, 2007 | 07:10 PM
PSI2HI's Avatar
Former Vendor
Default Re: Boost gauge reading is off? (Outkast95LS)
Autometer boost gauge? I've had quite a few of those be off as much as 3 psi from what the gauge showed to what the dyno showed.
skuded
Apr 21, 2011 04:38 PM
hondaaccord94
Mar 25, 2006 02:59 PM
92eg6lsvtec
Jan 30, 2006 07:03 PM
vangc6780
Apr 26, 2005 10:10 PM
T3T495GSR
Aug 20, 2003 04:23 PM
