Helmp with Map bypass valve
Old Jan 18, 2006 | 06:41 PM
alexb16hb's Avatar
Default Helmp with Map bypass valve
Hey guys sorry for the newb question. I have a 95 civic with a B16A 92-95 (SiR-II) engine. The map is not on the throttle body. Wich Map bypass valve do I need. Thanks guys!
I will be going with the Blox bypass valve
Old Jan 18, 2006 | 09:13 PM
spoon95eg's Avatar
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
Default Re: Helmp with Map bypass valve (alexb16hb)
U need a 3 to 4 check valve napa have em and buy some T and vacuum hose conect the hose to the throttle body measure 2 inch from tb then put the T and doit all over again and then connect it to the mapsensor
Old Jan 19, 2006 | 01:59 AM
eastbay92cx's Avatar
Default Re: Helmp with Map bypass valve (spoon95eg)
chip your ecu and use uberdata or crome, please. much more versitile and (possibly) even cheaper than an fmu + missing link. good luck.
Old Jan 19, 2006 | 09:22 AM
Boosted Power's Avatar
Yeah, use Uberdata and you'll be fine.
Old Jan 21, 2006 | 09:42 AM
Synapse's Avatar
buy the real Missing Link, the Blox one will get dirty over time and stop working. It is a knock off of the first generation Missing Link design.
Visionist
Apr 27, 2006 09:02 PM
1fstevo
Sep 19, 2002 11:39 PM
zerofourLS-T
Jun 16, 2002 06:28 AM
JM Performance
May 22, 2002 07:07 PM
