head gasket
Old Apr 20, 2005 | 06:22 AM
ochsy03's Avatar
Default head gasket
im sendin my block to get sleeved at GE and im puttin in arias 83mm 9:3:1 flat top pistons. i need to get a cometic head gasket...i was told to get a .043" thickness and that would drop it down to around 9:1 compression. also im getting my block O-ring will this affect what kinda of head gasket i get? thanks
Old Apr 20, 2005 | 11:09 AM
ochsy03's Avatar
Default Re: head gasket (ochsy03)
ttt
Old Apr 20, 2005 | 11:59 AM
turbo*s2k's Avatar
If that's what they told you to get you should get that one... Good luck
Old Apr 20, 2005 | 01:23 PM
ochsy03's Avatar
Default Re: head gasket (TurboChrgd_Civic)
thanks....anymore smart people here?
Old Apr 20, 2005 | 01:30 PM
BluePrintmfg.com's Avatar
Banned
You have no problem with the head gasket that you mentioned. Good luck with your build.
Old Apr 20, 2005 | 02:19 PM
X-Mazda 3 Racer's Avatar
Default Re: head gasket (11sec.ALL MOTOR)
With your block being o-ringed, use their standard gasket, NOT the HP gasket. The HP gasket has a built in fire ring that is NOT compatible with an o-ringed block
Hope this helps.
Vince
Old Apr 20, 2005 | 06:40 PM
ochsy03's Avatar
Default Re: head gasket (GoldenEagleMfg.com)
i just wanted to verify that the .043 thickness will lower the compression to around 9:1
Kyle Hufford
Jun 18, 2019 09:41 AM
byohnd
Nov 14, 2005 08:07 AM
92HB_HB
Sep 12, 2005 09:28 PM
hondafanatic1
Feb 19, 2004 05:35 AM
