Hanging/ high idle after boost
Old Aug 30, 2013 | 11:46 AM
dcalsv02's Avatar
Default Hanging/ high idle after boost
2000 civic ex, b18c1, after market intake manifold. while daily driving i dont have issues with the idle. If i get into boost more than a little, I let off and the car will idle at 2k and stay there. If i cycle the key off and start back up it goes away. I was told it is probably the iacv. Just trying to get some other opinions/ideas on what it could be or just to confirm that it is in fact, the iacv. I can post more specs, just wasnt sure which ones were needed. thanks. I apoligize in advance if this thread has been covered a million times. I couldnt find the topic related to boost. Or if the turbo has any effect on it.
Old Aug 30, 2013 | 10:53 PM
turbohatch96y7's Avatar
Default Re: Hanging/ high idle after boost
What ems?
Need to hook up a laptop and see what the iacv is doing not doing.
Could be the compensation tables for the ect iat etc.
Old Aug 31, 2013 | 06:37 AM
dcalsv02's Avatar
Its on crome. Ill ask my tuner next time i see him. I didnt know iacv's were so spendy. damn.
Old Aug 31, 2013 | 08:20 AM
You could take the iacv off and see if the screen is cogged or damaged.
You could also check the coil by doing a continuity test. I forget how many ohms of resistance it calls for but should be around 12-14.
Do you have a fitv on the throttle body? if you have it its located directly under the throttle body. google the name for pics.
E85B18
Jul 29, 2010 01:02 PM
1FastCoupe
Dec 10, 2006 08:33 AM
8200RPM
Dec 22, 2004 10:02 PM
spike
Apr 28, 2004 08:39 PM
Pengo
Aug 2, 2002 07:09 AM
