h22a4? is it worth turboing?
Old Jul 20, 2012 | 08:21 AM
conertedrange's Avatar
Default h22a4? is it worth turboing?
I found a whole h22a4 needs to be redone cause the bearing in the bottom end went... not a bad deal for $200 as far as i see. But i heard the a4s arent the most coveted to build... why and why not? or is it just like any other and will it do ok? I plan on sleeving and the whole deal so no worries on that but should i pass on the a4?
Old Jul 20, 2012 | 09:40 AM
ryguy2588's Avatar
Default Re: h22a4? is it worth turboing?
The only reason people don't like the A4 is because it has open deck sleeves. The H22A has closed deck and can handle more boost. If you're going to sleeve and build it, then go for it. My friend has a completely stock A4 making 400 whp without any problems on a 6262.
Old Jul 20, 2012 | 10:02 AM
mafia's Avatar
Stock long block? Or just the sleeves?
Old Jul 21, 2012 | 11:17 AM
ryguy2588's Avatar
Stock block with dual valve springs and retainers in the head. That's it.
Old Jul 21, 2012 | 11:18 AM
ryguy2588's Avatar
He has an H22A closed deck that I built Manley rods and Mahle pistons that he will be swapping in soon.
ilovuall
Feb 21, 2010 03:47 PM
jon3zy
Apr 19, 2007 04:55 PM
red beast
Jan 7, 2006 05:44 PM
b_series_boy
Sep 27, 2004 03:01 PM
1.8T_EG
Jan 13, 2003 10:00 PM
