Guys or gals with PowerFC
Old Jun 11, 2002 | 07:35 PM
JRSCCivic98's Avatar
Default Guys or gals with PowerFC
Anyone out there running either turbo or supercharger with PowerFC? I'm interested to know what your timing maps look like in boost... Or more to the point, what should timing be in boost? My engine is a D16Y8... so I guess if you guys post B18 timing I should just drop it back by 2. Anyway, I'd really be interested.
Also, let's say you run the stock JR with the FMU bs setup and then you run 10btc like they say... Obviously your timing even in boost can't be less then 10, so does that mean that if your timing at 0 psi and 0 vac is 38 at a given rpm, then when in boost it should be 38? (This is with stock ecu and stock JR kit setup...) Or am I getting this all wrong???
Please help...
Old Jun 12, 2002 | 12:54 PM
Default Re: Guys or gals with PowerFC (JRSCCivic98)
I know someone out there has a PowerFC... Or even if you don't, any standalone system is going to be the same when it comes to timing in boost...
Old Jun 12, 2002 | 04:55 PM
boosted3g's Avatar
Shooot me an email at Boosted3g@aol.com and ill give you my map. Please include what version you have and what type of map sensor (2 or 3 bar). i do know for a fact that i run way over 10 degrees of timing under boost at high revs. My car is at our shop but if i remember correctly it is about 23 deg with 24 psi @ 8500 rpm but dont hold me to it.
Old Jun 12, 2002 | 07:44 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: Guys or gals with PowerFC (boosted3g)
yeah,i think mine is around 22-23 under full boost.e-mai lme and i will look in the car for more details.
93civciv
Dec 4, 2007 05:23 PM
miro_gt
Sep 19, 2005 02:17 PM
mattcalica
Oct 4, 2004 09:48 AM
MintFlavored
Apr 22, 2004 02:59 AM
willyboyK20
Oct 30, 2002 09:50 PM
