Gt35r question
Old 05-25-2011, 11:23 PM
m00genwant2b's Avatar
Default Gt35r question
Just a question. I recently put a full-race turbo kit on with a gt35r and I took it for a test drive and it's not tuned but I don't hear the turbo spoolin but I only rev it to 3,000 rpm bc it's not tuned yet. But when does it start to spool is my question?
Old 05-26-2011, 12:05 AM
EF_NITROUS_FEED's Avatar
Default Re: Gt35r question
my buddy had one and it was reather hard to hear it spool...
Old 05-26-2011, 05:38 AM
Moderator
TheShodan's Avatar
You're not going to hear much at only 3,000rpms and being way outside of its efficiency range, as the turbo is barely building pressure and going past initial inertia. In addition, if you have one without the anti-surge compressor cover, it may be even quieter after you do get into positive pressure.
Get it tuned, turn up boost pressure, you'll hear it soon enough.
Old 05-26-2011, 05:45 AM
MR.johnson's Avatar
I wouldn't even try to hear it spool until its tuned
Old 05-26-2011, 02:41 PM
Silva Bullit DC4's Avatar
This , and this.
To give you a general idea, my old GT-35R started making pressure at WOT at roughly 3.5k RPM, and reached maximum pressure (full spool) at around 4.5 to 5k RPM. This was with an 84mm, stock stroke GSR with 9:1 compression & 98+ spec. ITR cams.
Old 05-26-2011, 05:53 PM
turbociv910's Avatar
just keep going, it will eventually spool.. itl be fine a couple times untuned.
team2dcrx
09-08-2014 05:28 PM
EJ8 GSR-T
11-12-2007 04:21 PM
UNforgivABLE
12-20-2005 05:33 PM
enigmaspeed27
01-31-2003 06:28 AM
not so civic
08-30-2001 06:08 PM
Quick Reply: Gt35r question
