Build Question..
Old May 8, 2011 | 10:38 AM
redline1320's Avatar
Default Build Question..
Hey guys..I have a few questions about my turbo build I have going on...so far I have a aeb sleeved b16 bored to 84.5mm and im going to be running eagle rods with supertech pistons..head will have proper valve train to run pro2s with a skunk2 IM and a lovefab ram horn manifold w/ a sc61 precision turbo.
My dilemma is that I just got a si w/ a b16 that has a set of skunk2 pro 2s in it..im wondering if my setup will be enough to run these cams and get good power gains out of them while staying reliable or should I just stick with my gsr cams I was previously going to run?
Thanks in advance for any help/advice you guys can give.
Old May 8, 2011 | 11:56 AM
b16bri's Avatar
Default Re: Build Question..
whats your power goals and how much boost u plan on running. I believe pro2 are generally used in higher boost application over 20 i think. Gsr are good theres a lot of good cams you can chosse between the two of them
Old May 8, 2011 | 12:15 PM
Garage 808 Hatch's Avatar
Pro2s are too large of a cam for that sized turbo IMO.
Old May 8, 2011 | 07:41 PM
Power goals are roughly 450+...my tuner won't go much higher then that on pump if I make it safely...planning on running about 22-24 lbs.. Ya I heard pro2s are too big for my car and i've also heard that they can do some horrible wear on your motor running boost on them..
Old May 9, 2011 | 10:07 AM
thanks for the advice man..Ya wish I had the cash to go bigger..gt35r or something hehe..oh well.
Old May 10, 2011 | 07:49 AM
Afternoon bump...noone else has anymore info ?
Old May 10, 2011 | 09:46 AM
redline1219's Avatar
This topic has been discussed at great length many times...
Pro 2s run a lot of overlap, and are not the best cams for your set up imo. With the size turbo and hp goals, I would suggest CTR/ITR cams for the most reliability and idle. If you have the cash and want to go with something else, I would considder s2 pro1s...
Old May 10, 2011 | 08:33 PM
first of all the name similarities are awesome lol...well thanks for the info..i'll probably just stick with the gsrs..running low on cash anyways right now..believe it or not tried searching up running boost with pro2s and just running them in general couldn't really find a whole lot suprisingly.. Thanks again for the advice..or will look into trade the 2s for the 1s who knows.
Old May 11, 2011 | 12:43 PM
Oh yeah gotta love that, our names are awesome lol
Good luck with that, keep me posted with some numbers, sounds like a sweet setup :-)
Old May 11, 2011 | 01:09 PM
Turbo-LS's Avatar
for your HP goals the gsrs will work just fine and give you a broad powerband, not as much peak power but more useable street power, Enjoy
dE.fUsEd
Jun 22, 2011 07:50 PM
saviour250
Apr 8, 2008 05:59 AM
ghostofnyc
Dec 26, 2007 12:49 PM
EK4Vti
May 26, 2006 04:46 PM
99b18
Dec 27, 2004 06:32 PM
