Trim and ar?
Old May 20, 2004 | 09:31 AM
civic_hatchback's Avatar
Default Trim and ar?
When people say they have 56 trim and .80 ar or whatever, what does that mean? Im not a real turbo guy so i have no clue what the meaning is. Sorry if this is a repost but i figuered someone could tell me real quick, thanks.
Old May 20, 2004 | 09:54 AM
Sohc Driver's Avatar
Default Re: Trim and ar? (civic_hatchback)
Trim refers to the size of the wheel
AR refers to the air flow ratio
With a turbo you have two AR #s. One for the compressor side and one for the turbine side. The turbine side is really what most people consider. And typically the higher the AR, the higher the boost lag you may get. But this also means higher topend horsepower. The lower the AR, the quicker the response and spool, but at the sacrifice of top end power you could make with a higher AR. You just have to decide for yourself what kind of power you are looking for and go from there in deciding what turbo to get. Also, the AR is dependent on the turbo housing.
The same goes pretty much for the wheel sizing (Trim). The bigger the wheel..the more lag you will face, but yield greater top end gains.
I hope this helps
Khoi
Old May 20, 2004 | 09:57 AM
-Trinitron-'s Avatar
what he said...
i was gonna say about the same thing but I let khoi go first...
Old May 20, 2004 | 10:02 AM
Default Re: (-TRINiTRON-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -TRINiTRON- &raquo;</TD></TR><TR><TD CLASS="quote">what he said...
i was gonna say about the same thing but I let khoi go first... </TD></TR></TABLE>
Old May 20, 2004 | 10:03 AM
FOrSfEd's Avatar
Default Re: (Sohc Driver)
GOOD INFO
Old May 20, 2004 | 12:06 PM
Default Re: (FOrSfEd)
Thank you khoi. I shouldve just asked you on aim instead of posting it here. Thanks a lot, good info. Talk to you on aim later.
antoni
Dec 25, 2010 07:17 AM
Hoosier Daddy
Mar 28, 2004 10:36 PM
bottlefedintegra
Dec 12, 2003 06:17 PM
bluedelsol
Jun 14, 2003 11:37 AM
Acura_I-RS
Apr 13, 2003 06:42 PM
