gt35 water lines
Old Aug 13, 2009 | 11:22 AM
thegatekeeper14's Avatar
Default gt35 water lines
i have a gt35 and will be tuning so, do i NEED to run the water lines, also do i run an oil restrictor on the feed line?
Old Aug 13, 2009 | 11:25 AM
Autoworks's Avatar
Default Re: gt35 water lines
yes, you want to take every needed precaution running that turbo. Be sure to run the water lines and correct restrictor
Old Aug 13, 2009 | 11:37 AM
SilverEk3dr's Avatar
less heat... more power... longer life... Why not?
Old Aug 13, 2009 | 11:49 AM
redtegra's Avatar
you don't NEED to. but definitely get some hooked up sooner or later your turbo will love you back. and also i found out that my gt28 has a built in restrictor and i believe all of the GT series does so no need for a restrictor. i can post a pic of the inlet nipple if you guys would like.
Old Aug 13, 2009 | 12:32 PM
TheShodan's Avatar
Moderator
For the GT35R, YES, run the water lines. On the ball-bearing systems, there is still a lot of friction in the CHRA and the water lines dissapate that additional heat, allowing oil to perform its main purpose; lubrication.
The correct restrictor is .035" to use with this turbo. Yes, you must run this additional restrictor with your turbocharger.
Old Aug 13, 2009 | 05:38 PM
ok thanks,
Old Aug 13, 2009 | 05:40 PM
can i see some water line setups?
Old Aug 18, 2009 | 08:04 AM
eaddagwan's Avatar
x2
im looking to see how to run my gt35r. bump!
Old Aug 18, 2009 | 08:13 AM
dpetro1's Avatar
https://honda-tech.com/forums/forced-induction-16/why-cant-i-use-coolant-bleeder-valve-turbo-coolant-lines-2064275/
look at post #9, shows the spots to tap into for coolant lines. i suggest the kit from b&r, good stuff
Old Aug 18, 2009 | 01:55 PM
YARO.'s Avatar
Yeap I got the B&R setup also. I highly recommend it!!
Old Aug 18, 2009 | 02:27 PM
cjordan's Avatar
not trying to flame here,just inform. If you search you will find many pics and ideas for the water lines. There are several different ways to do it, some easier than others, but all serve the same purpose...
Old Aug 18, 2009 | 03:47 PM
eaddagwan's Avatar
i just searched myself earlier and found some interesting kit setups. bump for water cooling
Old Aug 18, 2009 | 04:20 PM
cjordan's Avatar
yea, there are some interesting places to source the water from and return it to...
Old Aug 18, 2009 | 05:07 PM
anyother pics?
Old Aug 18, 2009 | 05:15 PM
i got 3 days to do this, can i tap into the bottom of the radiator?
Old Aug 19, 2009 | 05:43 AM
dpetro1's Avatar
yes some people have done that. you could could install a fitting in the drain bolt hole to avoid welding if you wanted.
here is a great thread on water lines. https://honda-tech.com/forums/showth...hlight=coolant
boostedekhatch1
Jul 1, 2010 04:57 AM
Emakulate
Aug 12, 2007 11:35 PM
eg:R
Aug 3, 2005 06:47 PM
silverpenny
Apr 23, 2003 05:51 PM
