Why cant I use the coolant bleeder valve for turbo coolant lines.
I have never used the bleeder valve before and I would love to ditch the little valve and insert an -AN fitting in there to run a colant like to my oil/water cooler gt30r. Some people have said that this should not be done, and im just trying to figure out why? I was thinking of enlarging the hole slightly to allow for more coolant flow.
what do you guys think?
Re: Why cant I use the coolant bleeder valve for turbo coolant lines. (a1320addict)
could i use that big coolant drain bolt on the front of the head for the return coolant line?? So from the bleeder valve from the bleeder valve to the turbe, then from the turbo to the coolant drain bolt on the head??
I'd like to see a pic of this arrangment. I think it would look much cleaner than most installs of a water cooled turbo.
Can my return line(#4) can be plugged into my coolant bleeder valve? I would rather rather use the bleeder valve then tap into my radiator.....thanks for the delp addict.
Re: (V-SPEC 1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V-SPEC 1 »</TD></TR><TR><TD CLASS="quote">on that setup, is there enough pressure for the coolant to actually goes up to the turbo and comes out and into the radiator? thanks.</TD></TR></TABLE>
the way 1320addict is doin it is prob the best i have seen it is goin with the water flow and doing the same as the upper radiator hose. except is getting water right after the water pump before it sees the head. great way to run it.
i ♥ my honda
Global Mod
Global Mod
Re: Why cant I use the coolant bleeder valve for turbo coolant lines. (xsi-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsi-t »</TD></TR><TR><TD CLASS="quote">1320 how did you get that on the drain plug???</TD></TR></TABLE>
Take out the drin plug, tap it to 1/4npt, then install a 1/4npt to -6 or -8 an adapter.
Do NOT tap it while the plug is in the block! This was a junk block and was not re-used. (pic borrowed from abnaasefmb)
Or you can buy this fitting from honda and go the much less expencieve route and just clamp your hose on. (I believe this fits but don't quote me on that, check first)
Re: Why cant I use the coolant bleeder valve for turbo coolant lines. (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>Nice man thanks
Re: (V-SPEC 1)
Thats really the million dollar question. Do you people realize that there is very little pressure drop between the bleed plug and drain plug? If you don't have a pressure differential, then water won't move. The pressure drop from the fittings, tubes, and turbo passages has to be greater than that pressure differential between the two water taps. I've actually considered drilling a hole behind the water pump (into the block), and tapping a 1/8" or larger fitting to get coolant directly after it leaves the pump fins. Its mainly for increased flow (highest pressure at that point), not because its much cooler.
IMO the best spot besides that for the supply is the drain plug, and for the return it would be as close to the pump inlet as possible. The FITV hose would be best (bypasses t-stat for just the turbo), or any hose that goes to the t-stat inlet cover.
Re: (HiProfile)
Bump for an answer to this question!
Re: (TunerToys)
I used the bleeder valve. I drilled and tapped it for a fitting I got from Stan@Fastturbo. I run a -6 line from there to the turbo. Then I have another fitting welded to the bottom of my radiator tank for the other -6 line. Seems to be working, but I did notice my temps go up about 8-10 degrees.
Re: (BodyKits NW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW »</TD></TR><TR><TD CLASS="quote">I used the bleeder valve. I drilled and tapped it for a fitting I got from Stan@Fastturbo. I run a -6 line from there to the turbo. Then I have another fitting welded to the bottom of my radiator tank for the other -6 line. Seems to be working, but I did notice my temps go up about 8-10 degrees.
I'm okay with using the bleeder valve as a return for the coolant, but am wanting to know if anyone has first hand experience with the flow results of the setup mentioned below.
BTW instead of tapping and messing with the bleeder port, you can use one of our water port adapters (for the D series only, so far.). Here is a pic...
You can use it to install a water return, and a water temp sensor, and still have the stock bleeder.
Anyone have an answer for how much flow you get with the setup mentioned earlier?
Craig
Craig
