is my compression too high?
Old Jul 22, 2002 | 07:49 AM
Charlie Moua's Avatar
Default is my compression too high?
*B20 with JE 10.5:1 or should i get somthing less?
*What would you reccomend?
Boost between 6-10psi mainly 6psi.........tuned with hondata
Old Jul 22, 2002 | 08:05 AM
SiRkid's Avatar
Default Re: is my compression too high? (Charlie)
i think youll be alright if you stay at that boost level!
just make sure things are tuned properly
Old Jul 22, 2002 | 08:08 AM
BoOsTeD_eK's Avatar
Default Re: is my compression too high? (SiRkid)
you'll have nice power throughout the band...just have it tuned properly.
Old Jul 22, 2002 | 08:09 AM
DC2R714's Avatar
I am running stock ITR comp. 10.6:1 with 6.5psi and everything runs good. Just dont run more than 8psi.
Old Jul 22, 2002 | 08:52 AM
Default Re: is my compression too high? (BoOsTeD_eK)
yeah that's what i wanted..... because I wasn't too excited about going turbo if i had to run 9.1:1 compression. I'm basically just looking for a nice higher than normal B20 turbo, and wider power band.
ONE MORE question::::::::: what would be a good mild/not wild turbo kit on this motor? Greddy, HKS, ???
Old Jul 22, 2002 | 08:56 AM
lsvtec101's Avatar
id use a turbo that makes power from mid to top end all depends what you want my t3/t4e has full boost at like 3200+ but i have a low trim all for bottom end.
Old Jul 22, 2002 | 11:58 AM
Default Re: is my compression too high? (aemcivic_02917)
any other opinion?
Old Jul 22, 2002 | 12:01 PM
CheezeFrog's Avatar
Bump the CF up another half point and you should be good to go...
B20vEFsedanBRUH
May 30, 2015 04:20 PM
CTGrey06RSX-S
Jan 5, 2008 06:07 PM
ej1 pilot
Jun 18, 2004 03:35 PM
Charlie Moua
Nov 8, 2002 05:08 AM
*Boostwerks*
Jun 1, 2002 01:24 PM
