Sleeving B16 questions?
Old Apr 14, 2006 | 01:15 PM
88crxhfb16's Avatar
Default Sleeving B16 questions?
Flame if you must. i'm new to this.
I am rebuilding my B16 and will be getting it sleeved. Is it possible to go 1.8? Since I will have the whole engine out of car??
Old Apr 14, 2006 | 01:20 PM
siblues's Avatar
Default Re: Sleeving B16 questions? (88crxhfb16)
Yes it is I am running a b16 thats at 1.9 right now.
Old Apr 14, 2006 | 01:24 PM
88crxhfb16's Avatar
Default Re: Sleeving B16 questions? (siblues)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote">Yes it is I am running a b16 thats at 1.9 right now.</TD></TR></TABLE>
can u explain what I need to do?? what parts will be different from the b16. i'm guessing the sleeves and pistons for 1.8. how about the crank rods etc.???
Old Apr 14, 2006 | 01:29 PM
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 &raquo;</TD></TR><TR><TD CLASS="quote">Flame if you must. i'm new to this.
You can increase the bore some, but the B16 has a shorter deck and stroke than the B18, which limits how big you can go. You can do all kinds of funky stuff with bigger cranks, shorter rods, and custom pistons with the wrist pins moved up, but it's not worth it IMO if you are turbo'ing it. I made over 400 WHP on a daily driven sleeved B16 and that was plenty for me.
Old Apr 14, 2006 | 01:35 PM
88crxhfb16's Avatar
Default Re: Sleeving B16 questions? (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">
You can increase the bore some, but the B16 has a shorter deck and stroke than the B18, which limits how big you can go. You can do all kinds of funky stuff with bigger cranks, shorter rods, and custom pistons with the wrist pins moved up, but it's not worth it IMO if you are turbo'ing it. I made over 400 WHP on a daily driven sleeved B16 and that was plenty for me.</TD></TR></TABLE>
thanks, I dont want to mess with the stroke. I am just gonna leave it 1.6 I guess.
Old Apr 14, 2006 | 01:38 PM
EK FLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 &raquo;</TD></TR><TR><TD CLASS="quote">thanks, I dont want to mess with the stroke. I am just gonna leave it 1.6 I guess.</TD></TR></TABLE>
or u can get a gsr block and get it 84 mm
TurboIntegra's Avatar
You do not have to mess with the stroke. You can sleeve it to 84mm which would put bump your displacement up to about 1.8L
Old Apr 14, 2006 | 01:44 PM
rmcdaniels's Avatar
Default Re: Sleeving B16 questions? (TurboIntegra)
84mm bore on a B16 will get you to 1.7.
http://www.c-speedracing.com/h...c.php
Old Apr 14, 2006 | 01:46 PM
turbofunvtec's Avatar
erl superdeck II
thats what i got
just shy of 2.0
Old Apr 14, 2006 | 01:54 PM
rmcdaniels's Avatar
Default Re: (turbofunvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbofunvtec &raquo;</TD></TR><TR><TD CLASS="quote">erl superdeck II
thats what i got
just shy of 2.0</TD></TR></TABLE>
A Dart tall-deck block got me to 2.156, but how much does he want to spend?
Old Apr 14, 2006 | 02:21 PM
Default Re: (rmcdaniels)
A Dart tall-deck block got me to 2.156, but how much does he want to spend?</TD></TR></TABLE>
not sure but this **** aint cheap
Old Apr 14, 2006 | 03:45 PM
88crxhfb16's Avatar
Default Re: Sleeving B16 questions? (TURBO-WAWA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBO-WAWA &raquo;</TD></TR><TR><TD CLASS="quote">
or u can get a gsr block and get it 84 mm </TD></TR></TABLE>
im not getting a Dart block or a gsr block. im using the block i have. Its gonna cost enough as it is.
Old Apr 14, 2006 | 04:21 PM
rmcdaniels's Avatar
im not getting a Dart block or a gsr block. im using the block i have. Its gonna cost enough as it is.</TD></TR></TABLE>
That's what I did for my first built motor, my 84mm sleeved B16 was awesome. 23 PSI of boost on 8.4:1 pistons and it was a lot of fun.
Old Apr 14, 2006 | 04:33 PM
SiKid86's Avatar
That LS block brought me to 1.8L and got it completly assembled with alternator for 100 bucks , Puttin forged parts in it now.
Old Apr 14, 2006 | 04:36 PM
88crxhfb16's Avatar
That's what I did for my first built motor, my 84mm sleeved B16 was awesome. 23 PSI of boost on 8.4:1 pistons and it was a lot of fun.</TD></TR></TABLE>
Can u help me out and give me a parts list? I want to build this one with the same parts U used on yours. Also what engine management did u use??
Old Apr 14, 2006 | 04:58 PM
rmcdaniels's Avatar
Can u help me out and give me a parts list? I want to build this one with the same parts U used on yours. Also what engine management did u use??</TD></TR></TABLE>
I've had a bunch of different setups, but here's the most mainstream:
My blown up B16A2, sleeved and head ported by RLZ.
Shelf stock 8.5:1 Wiseco Pistons on Eagle rods (I had custom 8.4:1 pistons in my first motor, but shelf stock coated 8.5:1 Wisecos are fine)
Motor assembled by RLZ, new Honda bearings and oil/water pumps
Stock B16A2 cams (they aren't that great, but they were free, you can pick up a set of GSR cams for &lt;$100 that would be better)
Lovefab SST manifold and 3" downpipe into a 3" TR turbo exhaust (pretty much any good tubular manifold with a clean full-merge collector, but the Lovefab units are the best built units that I have seen by far)
Ebay cheapie FMIC -w- homemade charge piping (Jegs 2.25" mandrel exhausts and ebay silicone hose couplers)
ATP Turbo GT3071R turbo with the big turbine housing.
TIAL 38mm WG, HKS SSQV BOV
AEM EMS, tuned by JDogg
Daily driven, weekend drag raced (usualy ran 12.0's at around 125 in a 2750 pound coupe)
Old Apr 14, 2006 | 05:04 PM
88crxhfb16's Avatar
</TD></TR></TABLE> nice numbers. what about valvetrain?? no way it was stock.
thanks for the help
Old Apr 14, 2006 | 05:12 PM
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 &raquo;</TD></TR><TR><TD CLASS="quote"> nice numbers. what about valvetrain?? no way it was stock.
thanks for the help </TD></TR></TABLE>
Ferrea valves and springs. The valves were fine, but the springs were way too stiff, they tended to make my cams and rockers eat each other. I use some RLZ springs now, no more cams eating rockers.
Old Apr 14, 2006 | 09:35 PM
rmcdaniels's Avatar
Also ARP head and main studs.
Old Apr 15, 2006 | 08:36 AM
88crxhfb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">Also ARP head and main studs.</TD></TR></TABLE>
thanks, yep ARP is pretty much a given. I'v heard the b16 head has great flow already, do u see any need for a port and polish???
Old Apr 15, 2006 | 08:42 AM
rmcdaniels's Avatar
I'v heard the b16 head has great flow already, do u see any need for a port and polish???</TD></TR></TABLE>
I'm not qualified to make a call on that, I rely on RLZ to make the head right for my application. I've heard from Brad at RLZ that a lot of flow improvement comes from just the valve job, so I'd at least get a good valve job done on it. It's pretty easy to pull the head off of it later if you want to get some porting done, so as long as the bottom end is right I'd say do whatever you can afford on the head.
mrx
May 12, 2008 07:50 AM
Natural Aspirations
53
Jun 12, 2006 12:48 PM
mugenman20
Sep 9, 2004 06:02 PM
b16wanter
Jun 17, 2004 04:10 PM
DubyaAye
Jan 11, 2004 10:57 PM
