Greddy Question
Old Mar 29, 2003 | 06:19 PM
boostsohfast's Avatar
Default Greddy Question
I read somewhere that you can T off of the vacuum line to the wastegate and run a vacuum line to the nipple on the greddy type-s blow-off valve that reads atmoshpere pressure to eliminate any turbo shutter prior to the blow off valve opeing up. This little trick works great, but it also upped the boost. As it spools up, it will go near 8psi for a split second, and then back down close to 7psi. I've decided to leave it that way.... It works great and doesn't detonate. Anyone else do this or run into the same thing?
Old Mar 29, 2003 | 06:21 PM
wReXeRw's Avatar
Default Re: Greddy Question (boostsohfast)
i think that trick is cool, but not really safe, it seems like youre boost spiking around a bit, and 1psi is a lot in my opinion.
Old Mar 29, 2003 | 06:37 PM
5thgencivic's Avatar
OT, how much did your car weigh in at with the run in your sig?
Old Mar 29, 2003 | 08:36 PM
Pengo's Avatar
did you have it set up like that today when u were makin ur runs? did u ever get those drags from ur friend? i think i saw u run some car that like broke down in its last pass. sorry to go off topic man
Old Mar 29, 2003 | 08:40 PM
Default Re: Greddy Question (Pengo)
My car weighed in at 2410 with me in it. Yea thats how I had it running today. I've been running it like that for a while now. My friend brought the drags to the track when I was already in the staging lines and about 5 minutes from lining up so I didn't use them. The last round I raced I had a .475 redlight against that car that broke. I would have won so easily too. The kid had a 1.0 reaction time so he pretty much gave me .5 right from the start.
Old Mar 30, 2003 | 02:48 AM
That's a nice run! What do you usually launch at? I have a 95ex(d16z6) with a greddy kit usually running 6psi and I'm having a hard time getting launches down. It's on street tires until I get some drag radials, but just curious. Thanks for any help you can give...
Old Mar 30, 2003 | 07:08 AM
Default Re: Greddy Question (5thgencivic)
I still haven't gotten that good at launching with street tires. I usually launch around 4k, feather the clutch and when its fully engaged I give it enough gas in first gear so that the tires are as close as possible to losing traction. Then when I get near redline, I shift into second and floor it.
Old Mar 30, 2003 | 11:01 AM
Ah, ok. Every car I raced beat me off the line last night But I was dumping the clutch instead of feathering it. Need to practice Thanks for the help.
Nate
Old Mar 30, 2003 | 11:23 AM
QCKGSR's Avatar
nice times
Drkaccrd
Jun 3, 2005 06:18 PM
boostincoupe
Jan 24, 2005 02:31 AM
95gsrturbo
Mar 17, 2004 11:51 PM
Chillinit
Mar 3, 2004 09:54 AM
uneekcrx
May 27, 2002 03:48 PM
